A
Non-HP Toner Cartridge installed
error message occurs in the following situations:
Non-HP cartridge is installed
HP cartridge is not installed correctly
False error
Sensor issue (hardware)
SOLUTION:
The
error message could be cleared completing the following steps:
All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards.
1. Verify that you are using a legitimate
HP toner cartridge by going to the HP LaserJet and Color LaserJet
Printers - Counterfeit Print Cartridges webpage.
Click
here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit
(http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270)
2. Remove the toner cartridges, clean the
metallic contacts by a dry linen cloth, and then reseat the toner
cartridge, and check if the error occurs. To reseat the toner
cartridge, see the instructions at the HP Color LaserJet 2600n Printer -
Changing Print Cartridges webpage.
Click
here to view the HP Color LaserJet 2600n Printer - Changing Print
Cartridges webpage
(http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345)
3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com.
4. Restore the factory defaults in order to restore the default settings:
a. Use the left arrow or the right arrow button to select
Service
, and then press
SELECT
b. Use the left arrow or the right arrow button to select
Restore defaults
, and then press
SELECT
If the issue still persists, even after
completing the troubleshooting steps provided, then use one of the
following support options so that HP can work with you to resolve the
issue, because it may be related to printer hardware where it needs a
live interaction
