Question about Toshiba e335 Pocket PC
Synchronisation under Vista is not possible with Microsoft Active Sync. Are there Alternatives available? My pda is Toshiba e...
Posted by neupertb on
Anonymous
    New Friend:
Hi, my phone is g900
but i canot remember my code
is there any way to unlock it ?
Posted on Oct 26, 2009
Active sync
Depending on your OS, you'll need Windows Mobile Device Center 32-bit or 64-bit. ActiveSync is for Windows XP machines;
Microsoft Windows Mobile Device Center 6 1 for Windows Vista 32 bit
Windows Mobile Device Center 6 1 Driver for Windows Vista 64 bit
Thanks
Jay
Sep 29, 2013 • Symbol MC70
Want to download from pda to PC
Use Microsoft Active Sync if your PDA is compatible to Microsoft software via a USB cable. If not Microsoft, consult your PDA manufacturer for how to sync.
My device won't sync with pc
What is your device? Windows?
If windows install the Active Sync and then plug the USB for PDA.
PS: Active sync is a Microsoft software to sync PDA with PC!
1helpful
I dont have a softwre to sync my PDA with my pc
there is no such thing as a benq pc suite...
the cd only contains trial version of
pocket outlook <--------- this cannot be downloaded anymore due to the release of the new windows mobile office
presentation dx (pocket point beta) <---- you can download this at....www.download.com
pocket version of adobe reader <---- you can download this at www.adobe.com
________________
if you need the program for syncing the device do the following:
if your pc is windows vista you dont need the active sync sotware by microsoft... because there is a preinstalled software included with the os... (its called windows device center found in control panel)
if you're using windows xp (all versions except x64) here are the download link of Microsoft Active Sync...
active sync 4.5 (xp sp2 /sp3) http://www.microsoft.com/downloads/details.aspx?FamilyID=9e641c34-6f7f-404d-a04b-dc09f8141141&DisplayLang=en
active sync 4.2 (support for almost all xp formats xp, 2003, sp1, media center)
http://www.microsoft.com/downloads/details.aspx?FamilyID=7269173a-28bf-4cac-a682-58d3233efb4c&DisplayLang=en
Nov 22, 2008 • BenQ P50
HP Jornada 548 files won't sync with Vista PC
No need to! all u need is to download windows mobile device centre at:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx
that should help you!please do rate if it does,regards!
2answers
Not able to sync
just download the Microsoft ActiveSynk and then you will be able to connect your PDA with computer without any problem.
here is link for ActiveSynk 4.5 and it is 7.5 MB in size
http://www.microsoft.com/downloads/details.aspx?familyid=9e641c34-6f7f-404d-a04b-dc09f8141141&displaylang=en&Hash=kobrjlqlKZQkwMyrfT3rC8EaIiQX%2bkCRIsBb8OaROrKfw0fTq%2bVvkRvkqpPNdP013MSh%2bVtZuhUdRe8wyjiQRg%3d%3d
all the best
Was this solution helpful? Show your Appreciation by rating it:
Sync toshiba pda to pc w/vista
I also have had this problem.
If you allow the Windows Mobile Device Center to install through the automatic updates, it works for the most part. I've gotten it to actually sync both from the pc to the pda and vice versa. However, it is a little finicky; it takes about 4 attempts before the sync is happy.
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Toshiba e335 Pocket PC Logo
Top Toshiba Computers & Internet Experts
Ekse
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
