Hi, I have an OKI C5600 printer. Printer has been working fine. The M Magenta cartridge was low/empty. I have replaced this with a new full one. But I was still getting the warning message. Now I get 411 toner empty message and printer will not even print black and white. Reading other FAQ, I tried to turn on printer while pressing menu button. Didn't help. I can't get to any of the menu pages, none of the buttons seem to work now that I have this 411 error. I have taken the cartridge/drum unit back out a couple of times and cleaned what I think is the sensor, but nothing is/was dirty and lever for the toner is right over in normal position. thanks Chris.
Kedves Mindnyájatok! AZ alábbi hibaüzenet jelenik MEG AZ OKI C5600dn kijelz?jén Minden szín? tonernél. Sot MEG AZ eredeti sárga-NAL van. Chip cserével lehet orvosolni SEM a problémát. Eddigi javaslat volt: 4 db toner éS alaplap csere. Ennyiért pia con színes nyomtatót is lehetne mar venni. Tudnak segíteni? Van Valami praktikus javaslat a hibám orvoslására? További Szép estét kívánok! Lacika
take out the magenta cartridge. and make sure the edges are clean. There are little metal pieces on the sides where the sensor reads the cartridge. Also, make sure the "lock" on the cartridge is locked.
Take cartridges out of the printer. Close cover. Unplug printer
for 30 minutes. Reconnect
printer to power. Printer demands cartridges. Reinsert cartridges as demanded.
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time. 2. Menu window will show OKI USER. 3. Scroll to Engine Dialog Mode is indicated Push Enter button. 4. Diagnostic Mode xx xx xx S Mode is indicated. 5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed. 6. Push Enter button. 7. TONER SENSOR - ENABLE is displayed. 8. Push Enter button. 9. Press (- / +) TONER SENSOR = DISABLE is displayed. 10. Press ON LINE CANCEL buttons at same time. 11. (*) is displayed. 12. Restart the Printer.
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
I had the same problem. I came across the 160 error after I moved drums around. My issue started with error code 161. which appears to be the Magenta drum. Moving it to other color locations gave me errors 160, 162, 163. 160, I assume, is the cyan cartridge, then 161 is the magenta, 162 is the yellow, and 163 is the black. In my case, the magenta was very dirty. I pulled it out, used an eraser from a #2 pencil to clean the contacts. Used the shopvac to clean toner power out of printer. Turned it back on and it worked.
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
THE TONER CONTAIN NEED TO BE WASHED OUT WITH SPECAL CHEMICALS, PRINTS NEED MAINTNANCE, OVER FLOW CONTAINER MAY HAVE TO BE EMPTYED ALL SO, CORRORNA WIRES NEED TO BE CLEANED
DRUM MAY MAY NEED SERVICE ALSO
Fatal Error 161-Toner Sensor Error, Color:Magenta When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black When magenta toner sensor error has occurred
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
