Posted on Oct 26, 2009
Canon mp140 not printing anything after refill
Hi, my Canon mp140 is not printing anything after refilling the black cartridge. Can u help?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 26, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
457
Points
MY PRINTER'S ALARM LIGHT IS FLASHING AND SHOW ERROR 2 CAN YOU HELP ME ?
1helpful
Mp140 printer- do I have to put both black and color cartridges? I have only black here and printer has an error.
Yes both ink cartridges need to be installed in the printer for it to work.
You will either need to purchase new Canon ink cartridges for your printer or refill your old ones.
Take care!
damnor01
4helpful
Dear Adviser The Canon cartridges for my Pixma MP140 printer have run out of ink as indicated both on the printer by the E4 signal and on the computer by a pop up window when trying to print a...
Hello, the printer Canon Pixma MP140 has cartridges with no chips. The printer reads the serial from the cartridge and tells you an estimated ink level. My recomandation is to press the resume/cancel buton for at least 10 seconds, that being the method to cancel the ink counter. After you press the resume/cancel buton you will be able to print, scan and copyas you did before.
The only disadvantage is that your printer will never show the ink level for this set of refilled cartridges, but it will work as well as brand new cartridges.
Hi, I just got a Cannon369 MP360 the black ink is empty,but there is color ink in it. It will not print anything. Do I have to replace the Black to get color in to work??? Since it's 2nd hand I don't want...
With this type of printer you need to have a full black cartridge to print black and white. The new Canon BCI-24 black cartridge from Staples is only $8.29. These cartridges are even cheaper from refillers. I recommend Cartridge World or Office Depot for printer cartridge refills.
7helpful
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
2answers
I placed a re-filled ink cartridges in my canon mp140 printer and
Computer chips in cartridges must be reset before the printer will recognize them as full. If you paid a shop to refill your cartridges take them back and complain. The best places will test the refilled cartridge before giving it to you.
Please note durability of prints using cheap ink is usually very poor, and as a result the manufacturers ink is usually much the better choice.
5helpful
2answers
I have a pixma mp10 scaner and printer it will not scan the light flashes E and 6. What can I do to fix this? Barbara Nash
Halo Barbara,
Did you mean Pixma MP140/160/150/170/180?. I never hear Canon pixma MP10. Well,it doesn't matter. Did you refill your cartridge?. Error code E6 indicates that ink level is not detected properly by the printer. It usually occurs in refilled cartridge. To fix this problem you need to deactivate ink level detection function by performing following procedure:
For MP150/160/170/180: Press START button (Black or Colour)
For MP140: Hold down STOP/RESET button for about 9 seconds
Please rate me as Fixya if this solution useful for you. Thanks
Source:
Canon Inkjet Printer Forum
Canon MX850 Empty Cartridge override
That code is "out of toner". I would try a genuine Canon Toner Cartridge.
221helpful
12answers
Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
old marine
old marine
ZJ Limited
ZJ Limited
