Question about Whirlpool Duet GHW9150P Front Load Washer
My duet wont finish the cycle it makes sounds but wont spin or drain. shows 5d on control panel
5 Suggested Answers
Coldcut
Karl Whisenand
  • 1554 Answers
SOURCE: My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Posted on Oct 31, 2008
Anonymous
SOURCE: "whirlpool duet makes big noise on hi spin cycle and sandy grey s
You have a big problem here. It sounds like the bearings on the drum shaft are going. this is over $400 for the back half of the outer drum and you have to be a very good mechanic to get it all apart. I currently have mine apart for the same problem which I verified by opening the door of the washer and lifting the inner stainless steel drum up and down with the machine off, of course. The tub is supported by two large ball bearings on the shaft that is supporting the stainless steel drum, and they don't sell just the bearings and seal, only the back half of the drum. If it has gotten bad enough to rub against the front half of the outer tub, it will probably have to be replaced also, about $120. This was probably caused by overloading the washer or washing something that was unbalanced and heavy; this destroys the seal between the inner drum and the heavy bearings, also not available separately, and lets water into the bearings in the aft outer tub which support the inner tub shaft. If you want to try to take this apart to verify, try looking at Whirlpool consumer services technical education group presents #L-68, Job Aid Part No. 8178076. I found it online. It has detailed instructions how to take this machine apart if you are a technician or a talented amateur, as I am. Good luck.
Posted on Apr 06, 2009
woobie dog
woobie dog
  • 1273 Answers
SOURCE: My Whirlpool duet washer is making very loud
VERY loud noises might indicate a loose counter weight. Open the cabinet then raise the top and check the condition of the counterweights and that they are fastened down properly. The front lower counterweight is held on at the ends by two lugs connected by a formed rebar rod and a spaced bolt in the middle of it. Check these first. Loose you can fix. If the rebar breaks, the counterweight will beat the inside of the machine up pretty good, usually damaging the water pump strainer housing. If this doesn't solve your problem, look at some of the other posts here for other ideas. They're really good.
Regards, --WoobieDog--
Posted on Jul 10, 2009
Howard Warren
  • 53 Answers
SOURCE: My whirlpool duet sport washer often finishes it's
Slow drain. Check your drain hose for kinks and make sure it's not partially plugged. If it is going into a pipe make sure it isn't pushed too far into it.
Posted on Sep 11, 2009
Neciforo Llanto
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
My Whirlpool Duet Sport front loader washing machine will finish washing the close but does not rinse then spin out the water. I have to turn it off turn it back on to spin and drain. I have used the...
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jun 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5d
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If the issue is still not resolved then c
heck the drain hose and make sure it is not plugged or kinked. After this check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU). Also check drain pump and pressure switch. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Problem draining. Getting 5d code.
Hi
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Thanks
Rylee
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
My whirlpool duet sport washer often finishes it's cycle with the symbol Sd or 5d, I'm not sure which one. Any idea what that means?
Sep 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer quits during cycle
That is a SUDS LOCK. Open the front panel to access the drain pump filter. Clean it out. Run several cycles without any detergent to clear out the soap being retained in the washer. If you are not using H.E. soap, switch to it. Use the amount of detergent specified on the package. Front load machines will not work correctly with excessive soap and the laundry gets no cleaner with more soap.Also use high water levels not medium or low. Use hot water whenever possible to reduce the suds residue.
Jul 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
unplug.
reassemble.
close panel.
finally .
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F21, 5d, and now not working
I had to call the Whirlpool service man. He came and concluded that the control panel was the culprit. He said it could be that the contacts were bad, but he didn't want to unstack the washer/dryer (dryer is on top of washer) to check it. He was suppose to call me to day with a price for another control. I'm just going to go and buy another machine. Can you recommend a reliable front loading washer?
Thanks for all your help!!!
Judy
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Display panel reads SUDS
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Oct 28, 2006 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
797 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
