Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer how do I get the washer off the control lock
Posted by freak_420200 on
jennyh7
    New Friend:
Washer doest not ask like it spin when it washers then it flashes 06 and f
Posted on Oct 26, 2009
Anonymous
    New Friend:
Take off the front panel below thedoor. reach up behind the lock you will feel a little knob. pull it down about 1/4 inch and pull door open.
3 Related Answers
prem mathew
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Kevin White
  • 1902 Answers
SOURCE: Describe your Whirlpool Duet GHW9150P
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Posted on Aug 15, 2011
29helpful
2answers
Describe your Whirlpool Duet GHW9150P Front Load Washer Problem the control lock button is on
Kevin
1helpful
Whirlpool Duet front load washer
If you push the end of cycle button for 5-6 secs. It turns the control lock on, do it again, and it turns the control lock off, on both the washer and the dryer
11helpful
Duet GHW9150P Front Load Washer: the control panel is locked...
Press "end of cycle" for 3 seconds, wait for a couple of minutes, try door. Do this again, it locks; this is the child lock feature.
1helpful
Duet GHW9150P Front Load Washer: The control lock light is on so I can't do anythin...
Depress the "end of cycle" button on your panel for 3 seconds, wait for 2 minutes, try the door. This is the child lock feature, do it again and it locks.
4helpful
16helpful
Duet GHW9150P Front Load Washer: control locked light stays on ,wont let you do any...
3helpful
How do I get our whirlpool duet washer control lock light off ?
Hold the end of signal volume button down for 3 seconds to turn the control lock on and off.
If that does not work then: a) unplug the washer or b) put the washer into diagnostic mode using the instructions from this thread http://applianceguru.com/forum2/1540.html.
2helpful
Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
