if you havent moved the ignition plate etc then remove cam belt and put top piston to tdc and the cam pully to tdc ( mark on head ) refit belt and rotate engine by hand to check nothing catching then try !
make sure its not the gearbox ! drop the box and try the engine again ! ive had this b4 !! when you used it last there was plenty of power and cooling ? easy to strip if it is seized ! please let me know more !
i have had this on mine and it was a sort of insect that made a mud nest in the small hole and it blocked the hole up ,try poking it out with a bit of wire
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
It's possible that a little fuel vapour come out of a carb on an hot engine that has just stopped.
Does the motor starts again and runs well in higher rpm ranges? Is the stall only when idling? If so, enrich the idle fuel mix ( screw out the idle mix screws half a turn t a time )
