Question about Hotpoint Ultima WF860 Front Load Washer
My Hotpoint WF860 will spin on rinse/spin load but not on a wash
My Hotpoint WF860 will spin on a rinse/spin load but not on a normal or fast wash...is there a way to reset the washing machine?
Posted by anniebrown34 on
Michael Thorpe
    President:
  • 2,702 Answers
No its the programer at fult
Posted on Oct 25, 2009
Code F-02 on hotpoint WT960
Check and clean the filter and drain hose. Make sure the hose isn't kinked.
Apr 22, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf860 child lock button pressed by accident ,now no buttons work want to give fast spin,then wash next load.
Try holding down 'options' & 'select' together the light changes OR 'dry' & 'spin' OR hold down 'end of cycle'. Works for other machines, tell me what did it.
Feb 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WT860
check your belt if not that it will be yhe bushes on the motor they might need replaced or a faulty motor
Feb 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
448 people viewed this question
Top Hotpoint Washing Machines Experts
gbob59
Eric Taylor
Richard C Cohen
Richard C Cohen
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
