I bought a Sony camera model (HDR-HC1E miniDV) and it was working very well but it has recently happened to me a problem:That the camera would issue a warning that there has been moisture condensation, please stop working the camera for an hour and no longer work at all in addition to the touch screen stopped working despite the press of a button Rest. I could not return to the handbook(manual user) because I lost it long ago. I request your Excellency to help me find a solution .and I hope you send me the handbook(manual user) in support of the quality of your products. to you all my sincere appreciation and gratitude
An expert that got 10 achievements.
An expert that got 5 achievements.
An expert whose answer got voted for 100 times.
Expert
Re: HELP ME PLEASE
If moisture condensation has occurred, remove the recordable media (tape) and then turn off and leave the media compartment open for the hour the camcorder is turned off . The camcorder can be used again if the warning indicator does not appear when the power is turned on again.
Moisture condensation normally occurs when the camcorder is brought directly from a cold place to a warm place. It can condense inside the camcorder, on the recording media, or the lens and cause a malfunction. To prevent moisture condensation when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and seal it tightly. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature.
hi,
i have a HVR-A1E that uses the same mechanism and it is a real s...t, i used this cam only a few times and had same problem...
i found out on blogs that is a default on those cams... i had to buy another cam to be able to read the recordings i made !
i went to this solution, i bought a FW recorder that records in real time with included battery and hard disk, because the only really sure repair is to change all mechanism (more money than buying another cam !) and must be done by a professional because the mechanism is extremely sensible to mount and adjust !
i tryied many things: let the door open for a long time and then reboot, try to move a little gear that is the responsible of the problem, putting a bit of mechanic oil, and nothing worked !
the problem comes from a little gear that have troubles to move correctly, and this gear is also activating a sensor that says to the main board, that the door is well closed or not...
cheers,
mich
Tape mechanism problems can be quite complicated but theycan usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Perform the following troubleshooting steps and check whether it helps;
1. Check whether the issue persists with all the tapes. If the issue persists with a particular tape, the issue is with the tape. change the tape.
2. Check whether the battery is fully charged,
3. If the batteruy is nit fully charged, connect the Camcorder to the wall outlet using the supplied AC adaptor.
4. Then, reset the Camcorder by pressing the RESET button using a sharp-pojnted object while it is turned ON.
5. If the issue still persists, remove the battery pacjk and disconnect the Camcoredr from the wall outlet; then slide the power switch to ON position for at least 30 seconds. Then reconnect the AC adaptor to the Camcorer after 1 minute.
If the issue still persists, service may be requuired. Please cointact ur Camcorder manufacturer to get it serviced.
The LCD screen may be turned OFF.
To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
