1998 Saturn SL Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All of my locks keep clicking on my 98 saturn
Anonymous
Level 3:
  • Master 543 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
Answers
543
Questions
0
Helped
274130
Points
1601
The first thing i would do is make sure the spring inside the power door lock switch did not collapse and causing the door locks to click all the time,,,you should be able to tell just by pushing the door lock switch,,if not disconnect each door lock switch one at a time and see if it stops,and if it does then you know which one caused it
Saturn 98 wont hold charge, batterie light turn on and than car stop running... is it the alternator or the wireing
Alternator is your likely problem. The wiring isn't bad in saturns, just need to replace the belts when needed. Your problem though is definitely that it just doesn't keep a charge, so your alternator is responsible for your dilemma.
98 Saturn SL2, AC/Heater Clicking
You need to replace the heater/AC blower motor the motor shaft bearing is defective..
'98 Saturn SL1 won't start. Alarm system behaving strangely. Have power, turn key-nothing. Then it will start for no reason. Drove it home (20 miles), shut it off and it won't start again. Changed battery...
I had this same exact problem in a family member's Saturn. If you are opening the door with the key and not using the key FOB to unlock the doors, then the security system will not allow you to start the car. You will notice when this happens that the dome light will blink and you'll hear the relay in the BCM clicking.
In order to stop the security system from doing this: Make sure the car is locked with the key fob by hitting the lock button. Then hit the unlock button on the key fob once and then once again (I do it out of habit). Then open the driver side door, put the key in and it should start no problem.
10helpful
Power door locks going crazy
One of your door lock inside switches are bad.Find the one that doesn't feel right when you push it in either lock or unlock.The internal spring is broke causing the lock relay to keep try to lock or unlock until it gets hot & protects.
98 saturn fuse keeps blowing
most likey a incorrect taillamp bulb or mis installed tail lamp bulb.Or front marker lamp socket corroded.Good Luck
Car wont start
Locate the fuel pump relay and replace. shold be located in the fuse box that needed the Tap
Saturn sl 98, need code for stero, its on lock
turn key on and hold down buttons 2 and 3 for 5 sec. radio should display a 4 didgit code. call dealer for unlock code. after getting code use seek and scan buttons to enter code then press th am/fm button.
2answers
98 saturn sc2 horn keeps going off. I got a jump it started.
lock the car using the key to reset the alarm
Top Saturn Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Saturn Expert? Answer questions, earn points and help others
