Question about HP DeskJet F4280 All In One Printer InkJet
Why doesn't the HP Deskjet F4280 scan documents to PDF
I have tried several times to scan a document on my HP F4280 to PDF but it only will do TIF. How can I changed to scan in PDF. I have tried to changed the document when I open it up but it just doesn't work. I open the the HP solution center click scan document it open a window for TIF file it has a icon that says change settings so I then click on it but there are no options for PDF, only JPEG PNG and other than I have no knowledge of.
Posted by ojust1795 on
Bill Boyd
    Top Expert:
  • HP Master
  • 53,816 Answers
To get pdf files you have to have adobe installed in the computer
Posted on Jul 01, 2017
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: Samsumg SCX 4521F does it pdf?
If you are using the SmartThru software, the otpion to change the scanned format is in the same screen where you state the name of the document and settings for color, resolution, and others.
Be blessed.
Posted on Sep 29, 2008
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: I am trying to scan a document in to the HP
Make sure you are choosing scan document instead of scan picture. Also make sure you are scanning at a resolution of at least 151dpi. (see here). See this link for xp, and this link for vista. Please also consult this link to check for the possibility that you may need to reinstall the hp software.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 13, 2009
Anonymous
  • 19 Answers
SOURCE: New Laptop with Vista Scans Documents as .tif instead of .pdf Why
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf268
Posted on Sep 06, 2009
Sandy_sanz
  • 54 Answers
SOURCE: hp deskjet f4280 will scan but only shows the document as black
There is a hardware issue and the printer needs to be serviced
Posted on Nov 07, 2009
Anonymous
SOURCE: HP f4280 all in one printer connected to mac (osx
My computer can't detect my printer F4280 deskjet?What should i do?
Posted on Jan 12, 2010
HP DJ F2235 doesn't have PDF option to scan PDF
Scan to PDF requires third-party software and linking that software to the HP Solution Center. The HP imaging software only saves to BMP, DCX, FPX, GIF, JPG, PCD, PCX, and TIF. You need a program like PaperPort or save the document as an image and then convert it to a PDF (using Microsoft Office, another Office Suite, or a dedicated image to PDF conversion program.)
I wish that I had better news for you. PaperPort can be found for $50 from some vendors after rebate.
May 30, 2012 | HP DESKJET PRINTER, HP OR COMPATIBLE
My HP Deskjet F4280 all in one scans only to Photo Smart. I need to scan it to documents so I can send documents by email. How do I get it to scan to documents?
You need to install OCR by Iris software. This will allow you to scan and convert it to rich text file (.rtf) /editable text. Some HP AIO like HP c309a have free basic OCR software. you can download c309a full feature driver and software and just get the OCR software.
Mar 25, 2011 | HP DeskJet F4280 All In One Printer InkJet
How do you use the scanner?
INSTALL THE PRINTER DRIVER SOFTWARE. GO HP SOLUTION CENTRE AND CLIK SCAN DOCUMENT/PICTURE.
OR
DOUBLE CLICK MYCOMPUTER AND OPEN SCANER(F4280) NOW SCAN ALL THE PICTURER r DOCUMENTS
Sep 03, 2010 | HP DeskJet F4280 All In One Printer InkJet
I cannot scan (but I can print)on my HP Deskjet f4280 All-in-one.
ok try a new program.. you can download a Scan to PDF here http://3d2f.com/programs/24-602-scan-to-pdf-download.shtml... it a free great program to scan and manage your document. I hope this solution its useful.
Dec 27, 2009 | HP Ruggedized DC Car Adapter for HP...
Only scans in TIF form. Want scans in PDF form.
HP support has the following documentation: (Copy and paste the following link into the location bar of your browser)
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01487633
I hope this helps!
Dec 10, 2009 | HP LaserJet 3330 All-In-One Printer
Scanner wont scan
Be sure that you have the latest scanner drivers from HP, for your system and OS. Often an easy workaround is to use Microsoft Office Suite document imaging.
The ms program can be found in the tools folder of the suite...Plus is that is almost always works on most any scanner, the minus side is that it creates only a .tif or a .mdi file. To read those, you need to set your DEFAULT program settings to call the Microsoft MSP viewer, typically located C:\Program Files\Common Files\Microsoft shared\MODI\11.0.
HP has been working on solutions to this issue. Further, HP has LIVE, free support available online, try connect to chat.
Doc
Sep 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
hi,
abdsf268
Aug 01, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp deskjet F4280 i have just installed printer onto my computer when i try to print documents or pictures from the web it only prints a very small part of the document, just one or two lines of a 50...
Web page sometimes formated in odd shape/format you may need to print preview to see how it had been formated prior printing the page...this will avoid printing partial informatin and etc...
You may want to check below link to further help if you have any issue with HP F4280
http://etech.maiila.com/hp-deskjet-f4280-all-in-one-printer-driver-manual-software-download-and-troubleshooting-tips
Good luck!..
Nov 08, 2008 | HP Office Equipment & Supplies
HP DeskJet F4280 All In One Printer InkJet Logo
579 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
