Question about E-Machines 6809 Notebook
My sister has a patriot 2005 laptop and her son is connected to Bt hub, which is wireless,can she connect using an adaptor,but we don't know if it's wireless.? many thanks for a reply.
  • Anonymous Oct 26, 2009
    Thanks for the reply,how do we know if her laptop is wireless,she's had it a few years,i can't see a slot for a card or the aerial sign and what usb adapter would you reccomend please.
    carino
Burraq Consulting
  • 139 Answers
The BT Home Hub is a wireless Internet router distributed by BT. and yes she can connect to the internet.
Posted on Oct 25, 2009
Testimonial: "thanks for the reply."
  • Burraq Consulting Oct 26, 2009
    if there is no wireless adapter in the laptop then u should buy linksys, dlink usb adapter .....wireless b/g
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
Bt home hub 4
couldn't hurt to try a new one, but be warned, different manufacturers cards can get different speeds depending on the router you are connecting to.
Oct 03, 2017 | Belkin Computers & Internet
I cannot get these plug in units to pair or connect to the laptop. is it me or are they ****?
If you can install a wireless repeater it may provide a better signal.
OR
A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Sep 30, 2012 | Computers & Internet
Hi, since having a new BT home hub, my inspiron 6400 will not connect wirelessly unless I do a 'repair' with it. Sometimes it detects broadband but wont connect wirelessly. My son changed the channel...
Most people have to just work out the configuration by them selves BT do offer a lot of support (0800 022 33 22) Their equipement is pretty good and widely used.
By the way the most least used channels are 1,6,and 11 there might be a default but these are the most complete channels which do not overlap(RE;
cnannel 1]--2.412 Centre frequency(ghz)
channel 6]--2,437
channel 11]-2.462
Mar 14, 2011 | Dell Inspiron 6400 Notebook
Computer does not connect
NEW LAPTOP? Noticed a lot of post for same Laptop as same time.
If try to use wireless - you need to set-up wireless part of router and wireless part of laptop (Wireless Software).
Setup your network same it is on the PC.
Use Network setup wizard, if not know how in system manager, in the control panel.
Network Name is same on both, MYHOUSE is good.
The only thing different should be NAME, like SYS02,
PC would be SYS01, and IPaddress ( first 3 sections same as PC - Last section is indivual system - example follows:
PC = 192.168.1.40 then LT = 192.168.1.41
Suggest you hard wire laptop to router to verify network connection then work on wireless connection setup after you get connected thru hard line.
Mar 17, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a BT 2-wire hub with networked printer.
First thing, Does your printer have a wireless facility built in? If not it has to be connected to the hub with ethernet.
Normally setting up a wireless printer involves using cables until the set-up is complete. It's nothing to do with the router but all to do with the printer.
Best thing is to go through the manual.
Oct 14, 2009 | 2wire (1000-400108-001) Router
How do I set up a router to extend the range of a wireless hub?
You would normally set it up as an access point. But bridge would work too.
Jan 10, 2009 | D-Link DSL-G604T Wireless Router
Wireless never worked in Acer Aspire 3000 notebook ..help!
you have to install the wireless drivers, check it on cd
Oct 15, 2008 | Acer Aspire 3000 Notebook
E-Machines 6809 Notebook Logo
431 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
