Question about Pentax *ist DS Digital Camera
How do i convert files to fuji dp2 proam.icm - Pentax *ist DS Digital Camera
Posted by dennconroy on
89 f150 starts and drives about a mile and a half then dies. 10-20 minutes then starts and repeats. Can a lack of grease on the icm be the problem?
This could be a lot of things.
1. Catalytic converter is plugging.
2. Fuel tank vacuum due to no vent
3. ICM overheating
4. Vapor lock
Feb 05, 2017 | Cars & Trucks
How to change file format for video xp55 from MP4
You can use a video converter to do that. Try to search for a best video converter, some programs will help you convert videos without losing any data. And I found "Video Converter Std" is very useful, which supports converting videos of various formats. You can use it to convert your videos for your portable device.
Dec 26, 2012 | Fuji FinePix XP55 14MP Digital Camera Blue
1998 buick century code p0420
code p 0420 refers to cat converter system bank 1---efficiency below threshold====causes ---cat converter---wiring---HO2S (heated oxygen sensor, the one in the exhaust manifold before the cat converter)
code p 0300 is random misfires
I would suggest changing the HO2S as it reports to the ECM on exhaust content so that the ECM can adjust the air/fuel ratio
so it is logical that if that unit is not reporting correctly, the cat converter may be having trouble burning off the gasses correctly
The oxygen sensor(O2S) reads the results of the cat converter operation and helps fine tune the ECM settings
Mar 10, 2017 | 1998 Buick Century
How can I download a programme from BBC IPlayer to a DVD on my PC? Any help appreciated.
download video using a good down load manager or leecher ( i use IDM) then you need to convert the file to mp2 or avi using a video converter only then can you create a dvd
Jul 17, 2010 | Fuji Computers & Internet
My 97 grand am gt will drive fine, then act crzy staling out, shaking & it will cut off. try to start it back & it will try to start & do nothing. but if you wait for 30 mins to 1 hr it will...
Start with the simple and replace the fuel filter, if that did not help the stalling issues. Inspect the ICM, a faulty ICM will start to fail when it heats up and then start to work again when it cools off. Once the ICM fails 100%, the engine will not run at all.
Thank you for using fixya and as mentioned, start with the simple and repalce the fuel filter.
Apr 11, 2010 | 1997 Pontiac Grand Am
How do I change the AVI file extension on video images? I'm not able to email video attachments with the AVI file and have very limited application with my Vista software with .AVI. How do I convert AVI to...
Dear Deemax1,
There are hundreds of software available on internet to convert avi to wmv or to any other file format. I searched Google with "avi to wmv converter" and I received about 5,250,000 results. Please download any free software and that should do the trick.
Hope that helps. Please let me know in case any further assistance is required.
Regards,
Srinivas.
Jun 21, 2009 | Fuji FinePix S700 Digital Camera
Dp-o2 wont Import wav files from my pc
For wav files to be imported to the DP2 have to be 'mono' wav files. The DP-02 won't even show stereo waves in the fat area. So make sure you are converting any stereo wav files into mono first. That's usually the problem. They should also be 44.1 khz sampling frequency and 16 bit (I believe the DP-02 will accept a 24-bit wav, but the file will be truncated rather than dithered down to 16 bit while importing which may not be ideal for quality).
Hope this helps,
bd.
Jan 26, 2009 | Tascam 2488 Portastudio Multitrack...
Problem with pictures format
fuji raw file converter does the job,
Sep 07, 2008 | Fuji FinePix S5000 Digital Camera
Fuji mp4 player. have a photo file with jepeg pictures in the file but cant fugure out how to view them on the player.
Make sure the image type is completely compatible with the player. Also, some manufacturers have a Media Converter for picture files. check your user's manual.
Jun 07, 2008 | Audio Players & Recorders
Picture color is off
Google or lookup in windows help for
setting the color profile of my camera
setting the color profile of my screen
setting the color profile of my printer.
color profiles are methods to determine the disparate ways many items use to display color, by setting the correct color profiles in you pc's hardware items you can view images on the camera, screen or in print and have them look the same. it is possible that your display drivers do not have an appropriate profile for the fuji finepix, icc icm profile files are usually available from the makers, but you have to know which one,ma nd how to install it.
Sep 24, 2006 | Fuji FinePix 2650 Digital Camera
Pentax *ist DS Digital Camera Logo
129 people viewed this question
Top Pentax Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
halotheracer
halotheracer
Lee Hodgson
Lee Hodgson
Are you a Pentax Camera Expert? Answer questions, earn points and help others
