Computers & Internet Logo
Anonymous Posted on Oct 25, 2009
Runtime error crashes program - TechSmith Camtasia Studio (csbungmaint04)
  • Anonymous Oct 25, 2009
    Error Message:
    When I place video in timeline, OK
    When I add Title Clip to timline I get
    MicroSoft Visual C ++ Runtime Error.
    Have done all of these after searching for fix:
    Updated Windows (from you)
    Removed Google Toolbar
    Run Registry Fix
    Still get error
    Trevor
Anonymous
Level 3:
President:
  • Master 1,865 Answers
  • Posted on Oct 25, 2009
Anonymous
Master
Level 3:
President:
Answers
1865
Questions
0
Helped
598897
Points
5720
Runtime errors are sometimes caused when your windows updates are not current, try updating Windows
Anonymous
Level 3:
  • Master 11,896 Answers
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734633
Points
36074
Either you will need to update your Java program, or if you are using virtual machine, I would disable it and download Java.
You could also be missing a DLL file.
It should say what file you are missing if that was the case. Then you can go on the web and download it from many different sites.
2 Related Answers
Anonymous
  • 227 Answers
  • Posted on Mar 31, 2009
SOURCE: runtime error
Does the Program issue you the name of the suspect runtime library at any point? If it does, go get the latest version of the runtime from the NET, in a searchengine type the name of the file+ext. download and then copy it in the same direrctory (folder) as the one on your system now. NOTE: I would FIRST rename the one on your system as <currentfilename.current_extention>and then add .OLD to it.
Anonymous
  • Posted on Feb 11, 2010
SOURCE: Microsoft Visual C + + Runtime Error
I just recently install Window 7 ultimate on my computer and then Acrobat 8 Pro start acting up. Try to open PDF file it will open for a little while then this thing pop up said Microsoft visual C++ Runtime Library and Runtime Error. Then it shut down.
Anyone know how to solve this problems please help.
Karoon Yip
[email protected]
I want to know the signification on error9401
Runtime Error Runtime Error 9401 is a common kind of computer error that can be caused by damaged registry files, damaged .log files, faulty program installation and uninstall, serious virus attacks and application confliction. Runtime Error Runtime Error 9401 problems sometimes are hard to detect by Windows operating system itself and you have to restart your computer to get rid of Runtime Error Runtime Error 9401.
Runtime Error Runtime Error 9401 can lead to:
  • Blue Screen of Death Errors
  • Registry errors
  • Obscure computer errors like ActiveX Errors, DLL errors and EXE errors
  • Serious Malware Threats
  • Slow PC Performance
  • Computer & Application Shutdown
Visual c++ runtime library runtime error!
then ur computer is running without latest Microsoft c++ redistributed version. Do a windows update.
How do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
4helpful
3answers
Atari act of war: direct action runtime error?
First uninstall and reinstall the whole game. Then make sure you have the latest patch V1.06. If that does not help here are good instructions for installing AND running the game as administrator and with compatibility mode (if you are running Vista or Win7:
http://www.ataricommunity.com/forums/showthread.php?t=659761
This also has helped to solve a lot of issues:
http://www.ataricommunity.com/forums/showthread.php?t=455721
Karoon Yip
[email protected]
1helpful
Runtime error
3answers
Error messages. which cause my computer to crash.
what is your operating system?
what is internet explorer version?
if you answer these 2 questions I maybe able to help you resolve your problem
Runtime Error! I can't use IE?
If you have IE7, click on START, SETTINGS, CONTROL PANEL, ADD REMOVE PROGRAMS. Remove Windows Internet Explorer 7, reboot.
If you have IE6, click on START, SETTINGS, CONTROL PANEL, ADD REMOVE PROGRAMS, ADD REMOVE WINDOWS COMPONENTS, and uninstall IE (Internet Explorer). Reboot. Go back and reinstall IE. You may need the original XP CD. Borrow one from a friend if you can.
Top TechSmith Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a TechSmith Computer and Internet Expert? Answer questions, earn points and help others
