Artec DHM-G48 (ar16x) Internal DVD Drive Logo
Posted on Oct 25, 2009
Can not see dvd-ron in my computer icon,but it is in device manager.
Dvd code 10
Check the cord connection between the dvd player and the computer. Re boot the computer and then plug the dvd player in. Be sure the dvd player is connected to the power source.
You should "see" it on the computer as an icon if you are displaying the desk top
If not, click on the desk top Windows icon, and then click on Computer when the pop up comes on.
You should see the display of your computer and hard drives
The dvd player icon should show up under "devices with removable storage" there.
Re check the dvd is actually on.
Click on Control Panel and then "Hardware and devices" You will see your printer etc.
If the dvd player doesnt show up, try and open the dvd player to load in a disc. If the tray doesnt open, the player is defective
If it does, then the fault is in the computer "Device Manager"
Go to the computer Device Manager and you will see the device name with a red x against it.
The two possible faults are
1. The driver is missing or damaged
2. The device is defective
If you have the skilset, delete the dvd driver and install it again from the manufacturers (Toshiba?) web site
If you dont, find a geeky friend!
Cd-rom icon not exist on dell inspiron 1501
if it is windows seven computer
click on start from the left bottom of the screen, then right click on my computer/computer, then you will get an option of manage, click on manage
a page will open up, on the left side of the page there would be an option named device manager
once you click on device manager you will find a list of devices on the rigjht
then in the list right click on cd/dvd and you will get the option of delete and simply delete that
and then restart the computer
you will get the icon
When you click on computer it doesnt even show the icon for the dvd/cd player. I can insert a disk, and here it run; but nothing happens. I try to locate the program in the all programs file but it is like...
check the dvd/cd Rom connection inside cpu, if it does not work then
right click on my computer icon and select Manage->Device Manager->DVD/CD ROM drive
and the right click on that and select enable
it may help you
When i insert DVD in DVD drive...it shows only 0 byte space..when i open it, it shows blank.. why? any solution..
First try this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318
Delete the upper and lower filters.
Then, go to device manager uninstall the DVD device driver. Reboot the computer. Wait until the computer automatically detects the DVD device icon. If not then download the DVD device icon from Dell Support website drivers and downloads.
If all files replace the DVD drive.
Hope this helps.
My Cd drive not see in my computer & Cd Icon is not show in my Computer pls help me out for this problem urgently
You might have disabled the CD/DVD ROM in your Device Manager or in your BIOS.
In Device Manager:
1) Right click My Computer and choose Manage.
2) A window will appear. Go to Device Manager.
3) On the right side of the window, find CD/DVD and right click on it and choose enable.
4) Check if your CD/DVD drive is present already.
If you cannot find it still, try the BIOS:
1) Restart your laptop and go to your BIOS set-up
2) Look for CD/DVD drive and enable it.
3) Restart your laptop.
Hope it helps.
Thanks!
2answers
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Where do i look for details of the installed drives for my cd-rw and my dvd/cd-rw. its just a hands on question in my computer repair I class
goto control panel, open device manager... you can find all the drivers that are installed in your computer including cd/dvd drivers....
start > control panel > device manager (for vista & win7)
start > control panel > system > hardware > device manager (for xp)
or
right click on my computer icon, select manage > select device manager
I hit buttom on the side do not open or do I go in to the menu to open.
I understand that the CD/DVD Drive is not ejecting. Are you able to view the CD/DVD Drive icon in the My Computer window? Also check if the CD/DVD Drive is listed in the Device Manager. You can uninstall the CD/DVD Drive driver from Device Manager and restart the Computer and then try ejecting it.
I have a problem with a new machine--The DVD hardware is screwed up I need to remove the drive however it is a maze PLEASE help TNX Ron
wright click on the my computer then select device manage and again click on the device manager then click on the dvd drive then right click and unistall the drive.
DVD burning
From your cryptic description, and the extremely limited details given.
Does the DVD even show up on "My Computer"?
If it is not shown...
Go to your "Device Manager" (Right click on  'My Computer', select 'Properties', click the 'Hardware' tab, click
the 'Device Manager' button. Click the "DVD/CD-ROM drives"). If there is some kind of a "Warning" icon superimposed on the 'DVD drive' icon there is your problem!
Uninstall the DRIVERS for THAT DEVICE only.
Click on the faulty devise and hit the remove button, follow the instructions given by the program.
Shutdown, restart, the device will automatically reinstall by the "Found New Hardware" program.
Top Artec Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Artec Computer and Internet Expert? Answer questions, earn points and help others
