Logitech Cordless Click! Mouse Logo
Question about Logitech Cordless Click! Mouse
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Posted by pmontav on
Anonymous
  • 2,567 Answers
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Posted on Oct 25, 2009
How do I edit my calendar on the samsung galexy S II
To add an event:
1. Click on calendar app icon2. Click menu button (bottom left below screen)
3. Choose 'Create' (with the + sign)
4. Set time, description, notifications and other data for the event
5. click 'save' (bottom left of screen)
To edit an existing event:
1. Click on calendar app icon2. Go to relevant day, and click on relevant event3. Click menu button (bottom left below screen)
4. Choose 'Edit' (with the pencil icon) - note this option is only for events you have created.
5. Set time, description, notifications and other data for the event
6. click 'save' (bottom left of screen)
Double-click problem, how to fix it? Tks.
Usually it involves re-soldering whole button on PCB if DIY. Sometimes cleaning of button's internal parts might help. But if it is in warranty - I would definitely suggest to send it to repair center.
When I try to print, a large black vertical streak runs on the right side of the page, in the same place every time Sometimes the streak is a small line, other times it is very black and is 2 inches...
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
1helpful
Since changing the ink cartridge for the first time it now won't print. Sometimes it will print absolutely nothing although it seems to go through the motions but page comes out blank, sometimes it will...
2answers
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Nano mouse will not movethe cursor
Do you have the Nano 2007 model, or the Nano 2008? Procedures are different. The following link should help you:
Link 1 (resynching mouse)
Make sure you have fresh batteries and they are aligned correctly. If it still does not work, download the latest version of SetPoint and reinstall the softwrae after uninstalling it first.
Unresponsive left mouse click
I have that issue too. At the beginning I tought it was a connectivity problem but it does it even with the receiver side by side. Latelly it is working perfectly.
2answers
Logitech MX Revolution Left Click Button Broken
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Mouse wheel is inverted
if you are using Windows go into conrol panel and click on mouse. it will show you the options to change the buttons..
pls rate this solution
Top Logitech Computers & Internet Experts
Marvin
Marvin
Steve Nordquist
Steve Nordquist
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
