Question about Samsung WEP410 Bluetooth Headset Wireless Headset
Im trying to set up my blue tooth to work on my ps3 but no signal is found what am i doing wrong?
Posted by the_creeper_ on
Jan McZeal
    President:
  • 632 Answers
You need to pair your PS3 with your bluetooth headset.
  1. Turn on your PS3's bluetooth and search for bluetooth devices.
  2. While the PS3 is searching and the BT headset is off, press and hold the call/end button on the bluetooth headset until it's light glows steadily. Do not let go until the PS3 finds it.
  3. Pair the devices and allow the BT headset to connect automatically.
  4. To connect, press and hold call/end button on BT headset like the one in step 2.
Posted on Oct 25, 2009
Anonymous
  • 396 Answers
Go to settings check blue tooth the password allways is 0000
keyie
    New Friend:
Ok you cannot pair your phones bluetooth to the ps3 'manage bluetooth devices' menu . you can only pair your phone if you have software on the phone to make that bt connection. playstations use a certain type of bt radio and it differs from your obex type built into the fone. 1st off download sixaxiscontroller app for the fone . ull fibd it alover google free and paid versions. now switch on the ps3 goto system settings, accessories settings,register bluetooth device and set it off searching. now turn on the bluetooth on fone and tick visible . start the sixacisvontroller app and follow onscreen prompts from there . itll take around 3 mins to find te ps3 bt radio but it will pair fairly fast. when asked for pin or passcode use 0000 . once it finds the device .save the setings and exit.. ;) from now on just start the app and switch on ur bluetooth inc visible option ticked and the app will control the ps3 :) it makes your phone SPOOF the real playstation btcontroller so the system thinks your phone is infact a ps3 sixaxis controller . u can use the app to play gamwes with the onscreen joypad or use the fones accelloromiters to control games ;) .... pairing bt like this does NOT let u send files to ps3 it only controls it. to send and media pics vids music etc .... u need to do this via a media server . goto settings. network settings and enable media server option. now on your fone select your ALLSHARE app or download one! ... switch on your phones WIFI. make sure your PS3 is connected to your OWN router normaly as u would for using web on the system. in allshare select type u want to ply either Play file from your phone on another device or select play media from the ps3 on your phones inbuilt media player :) .... select the option play file from my phone on another device (this is gonna be your TV) .... select the folders to share and or files with a tick option . now select shate media . select search for Media server on the PS3 xbm menu and it will find your phone as a media server. u can now listen to all your music.pics vids and copy/move them around in the ps3 ;) ...sounds complicated i know but really It Isnt at all. takes as little as 5mins 1st time setuo and only a min or 2 there after! .... ive sent full length adult vids fom my fone to my ps3 and watched in upscaled sd on my 1080p led tv and its pretty good. just remember its using wifi and if you switch it off during streaming ull loose all the files u sent. if u need any further help or tips mail me at [email protected] ;)
Posted on Mar 21, 2013
  • keyie
    keyie Mar 21, 2013
    know alot about ps3s how to reset hardware and fix issues with broken updated os's to pairing bt headsets to mobiles n media. the new 4.40 update has fixed a few issues ingame but still nothing to connect a phone direct to it as yet. grr i have a few tricks that sony didnt tell you about the console and ive rarely seen any published info on the whole bluetooth radio kanundrum . if u people are having trouble pairing headsets then put te headset into paring mode FIRST then search on the ps3 for it. default codes are 0000 1234 1111 5555 .if non of tem work and u still cannot find the bt radio signal then try Reset te consoles Hardware. turn off console holding power button in . dont let go ok. now remove power cord for 30 seconds and release power on/off key. put power cord back in and press power on button in and hold it in untik u hear a 3 beeps...keep holding ull get 1 further beep and now let go of power. ull see a menu on screen with reset options . before u go ahead make sure your console is connected via either scart or standard av lead as reseting the hw will switch the consoles hd off .u can reactivate the hd after in display settings and select hdmi instead of av scart ;) ...the console will reboot andthe hardware will reset to factory setup . bddrive will re centre itself and check te mechanism. the signal for tv will switch hdmi to av . the ram will be cleared andany other memory dumps will be purged . the BLUETOOTH radio will restore itself to the 1st day it was ever used . now try agen to pair ur headset. if this fails then the problem is with the bluetooth module insife the ps3 and it will need repair. costs around 25pounds pr 32dollars max to replace ;)
  • keyie
    keyie Mar 21, 2013
    by the way if you dont have a plsystation PLUS account i suggest u get the 90day trial for a few pounds. before doing a HARDWARE RESET sync all your medals to ur online account and save all game saves and data to The PLUS App .failiur to backup omvia ps plus will result in a total data loss .no gamesaves,trophys , game addons and downloads from store...all will eraise wiping the harddrive clean! e warned ok
Hi. How do I bluetooth sgs4mini with my ps3?
You can't.only Sony ps3 made products connect to ps3..but u can try then on blue tooth on you r device..then settings in ps3.find accessories.. go in there find blue tooth devices do a scan..may or nay not see device..try USB connecting device
Jul 20, 2014 | Video Game Consoles & Games
I need to pair my bt2050 up to a new phone,it was originally paired wit another phone that i do not use anymore,im using a nokia x3 now and when im trying to find and pair up it says there is no device...
Hi Barbara,
Please follow the below steps, i hope your problem is resolved :-
  1. Make sure that your phone's blue tooth is out of hidden mode and , it now shows up as shown to all, in the connectivity settings.
  2. Make sure that you delete the pairing from the other phone , via it's blue tooth settings, if you are not using the phone and it's switched off , then you don't have to worry about it.
  3. Switch off the bluetooth and restart it , so that it's ready to accept new connections.
  4. Now go in your blue tooth option and search for a new paired device , it should reflect your Jabra blue tooth.
  5. If the above method does not work , sadly your phone does not support the Jabra blue tooth.
  6. You should also try connecting this blue tooth to someone else's nokia phone to check compatibility , if it's compatible with the other models, that means X3 is an exception to this compatibility.
Hope this helps.
May 11, 2011 | Jabra BT2050 Bluetooth Headset
My ps3 will not recognize any wireless controllers or blue tooth devices. My Ps3 BD controller, headset and six-axis will only work connected via USB. I tried the reset buttons on the six-axis but does...
Did they connect before and now won't or are these new bluetooth set up connections? If new connections:
  1. In the XMB™ home menu, go to [Settings] > [Accessory Settings].
  2. Select the "Manage Bluetooth® Devices" option to register (or "pair") a Bluetooth-compatible device with the PS3.
Dec 03, 2017 | Sony Wireless Controller for PS3
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I dont know the pass word for my blue tooth
If you did not yet set up a personal passcode for the blue tooth it should be 0000 or however zeros it may be. Im not exactly sure.
Apr 05, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
On my ps3 bluetooth scanning for a ps3 headset its
Make sure that your blue tooth is in pairing mode when the sysytem is scanning.(refer to blue tooth headset manual for intrustions)
I hope i have helped and I hope it works!!
Jan 07, 2010 | Sony Playstation 3 (PS3) Console
How do I register my blue tooth model 220
The passkey should be 0000 (four zeros) and you may want to review some new information we have now:
You may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Oct 10, 2009 | Plantronics Explorer 220 Bluetooth Headset...
PAIR TO PS3
you want it to get hooked up with the ps3? go to the blue tooth management setting then hold down the power button of your blue tooth until it starts blinking colors, most likely red and blue, then start the scan, after that you should be good, the code for the blue tooth is usually 0000
Jul 10, 2009 | Motorola Mobility HS850 Consumer Headset
Ps3 hooked to my motorola h550 bluetooth
Hold the button for a few seconds and it will connect.
Mar 31, 2009 | Sony PS3 40GB Best Sellers Bundle Console
Blue tooth is not installing for the ps3
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
Mar 31, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Samsung WEP410 Bluetooth Headset Wireless Headset Logo
814 people viewed this question
Top Samsung Radio Communications Experts
Anthony Ward
Anthony Ward
Ekse
Jean Thiebaux
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
