Question about Gateway 504GR PC Desktop
My cpu overheats - Gateway 504GR PC Desktop
Posted by macatog on
Puppet03
    Sergeant:
  • 172 Answers
Clean the cpu cooler slots and replace the thermal compound on the cpu ....make sure you clean off the old thermal compound .....only a thin layer of new thermal C will do all most see through ... hope this helps my friend
Posted on Oct 25, 2009
Steve
  • Gateway Master
  • 3,289 Answers
Overheating problems are the result of restricted air flow. Unless you have recently swapped the CPU, heat sink or CPU fan, a thorough cleaning should be all you need to do.
Shut down & power off the PC. Disconnect all cables noting where each is connected. Remove the PC to an open well ventilated area - and open the case.
Carefully vacuum dust and lint that has collected inside the case and on the motherboard. You should not touch the vac wand on anything - just hold slightly above the dust / lint. Inspect and vacuum ventilation holes in the case and interior components such as the power supply, etc.
Clean all fans and look for dust / lint build up in the air path of the fans. Fans can be found in the case, power supply and CPU. Some devices have heat sinks without fans. Pay close attention to removing much of the dust / lint from fanless heat sinks.
Check spaces between drives for dust build up and clear away.
There will be places that you will be unable to clean very well with a vacuum. Use a can of compressed air to blow out trapped dust and lint that the vac couldn't clear. These trouble spots are usually the Power Supply fan and ventilation holes and CPU fan and heat sink.
Reconnect the computer and leave the cover off. Power up and make sure all fans spin up (some may change speed as heat load increases - so use the PC normally so that heat that would be generated will trigger a fan to turn on. Clean / repair / replace any fan that is not working properly as soon as possible.
If you have swapped the CPU, heat sink or CPU fan, you must use the correct cooling system for the CPU. Additionally, thermal compound must be applied to the CPU to ensure maximum heat transfer from the CPU to the heat sink.
I hope this was helpful!
2000 sebring 2.5 stalls out and overheats
Have the fault codes read. Replace faulty items. Use only genuine items as non-genuine replacement are not always compatible with the OEM fitted CPU units. The engine light is telling you that the cpu has found a fault ( probably overheating) from a radiator fan not coming on. The stalling could be the cpu going into protect mode and stopping the engine
Overheat
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
My computer keeps shutting down after a few minutes. I have replaced the powersupply as well as the cpu fan. I am being told now that it is the system/motherboard. Is that an accurate answer?
When the CPUoverheats it goes into thermal shutdown and will not boot up again until theCPU has cooled down.
The heat sink may be clogged with dust, which causes the CPU to overheat byreducing air circulation through the heat sink.When you replaced the CPU fan, did you put new thermal heatsink paste on the CPU/heatsink? If not then the CPU can overhest. Your computer fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
Cpu overheats
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Laptop Overheats
Shut down during boot
Sounds like a cpu overheat situation. Check the cpu temps in the bios and compare the temps with the maximum operating temp of your particular cpu. It might need better/or/new cpu thermal paste applied to your cpu, and also check that your cpu fan is running and locked down tight (and not loose)
Why does not cpu work on more tera hertze?
A CPU is specifically designed to work as a certain frequency. Some motherboards allow overclocking to speed up the clock frequency and allow the CPU to operate faster. The faster the CPU operates the more heat it will generate.
When a CPU overheats, it will shutdown - this is called thermal shutdown and if this is allowed to continue, the CPU will eventually fail.
Cpu overheat
Check the heat sink .
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Beep sound when swith on
good day,
a beep from your cpu system means that there is an error. and since there is a "cpu overheat" error, it could mean that your cpu cooling system (or its fan) is not working.
the shutdown is a defense mechanism of your cpu in order for your cpu not to self distract.
have the cooling system replaced as soon as possible to avoid further damage.
i hope this will help
Gateway 504GR PC Desktop Logo
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Michael Thomas
Michael Thomas
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
