None of the parts are usable in any other machine.
The coolant from a liquid-cooled G5 PowerMac is toxic. If your G5 is leaking, disconnect the power cord IMMEDIATELY. Flush any skin exposed to the fluid with water for at least 15 minutes.
If you want to glove up and extract your hard drive from the machine so as to save your data, do it carefully. Other than that, my recommendation is to bag up the unit and handle it responsibly as toxic waste, using the same guidelines your area uses for antifreeze.
Just to clarify a G5 is not a Pro or "desktop Pro" (Mac Pro is an Intel based machine). Yours is a "Power Mac". Install a temp monitoring app to see the temperature (mainly the CPU temps). Mine runs around 50 to 60 Celsius and never more than 72. If the temps run to high she will shut down. G5 are great machines but it's not rare for them to go bad. Power supply issues and liquid coolant leaks are well know. Fans controllers have stopped working (the fans them selves are usually OK).
yes it seems that your laptop dose not meet the minimum requirements to install final cut pro software.you will need to purchase a laptop with the correct requirements,sorry. ken
I understand from your problem statement that the internal iSight camera in your G5 iMac turns itself off around 10 seconds after you turn it on.
Create a new temporary user in System Preferences / Accounts. Log out and then log in as this user. Enable the camera. Does it still turn off in 10 seconds? If not, something running in your other user account (a startup program or system preference) is interfering with the operation of your camera.
If you have a spare external drive, install a fresh version of the Mac OS on that drive, then boot from that drive. Does the camera still turn off in 10 seconds? If not, you should run an OS installation with "archive and install" on your internal drive. If it does, you have a hardware problem that requires a Mac tech. If this is indeed a G5 iMac, the repair will likely not be cost-effective.
Try a different wall outlet. If no go swap the monitor and tower power cables. I still no joy disconnect the power cord from the monitor, hold the power button for 10 seconds with the power cord disconnected. Try Plugin intu cable. If the screen is still dead check with dell tech support if the monitor has a warranty active on it. If the warranty is out get the monitor checked at a local computer shop.
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Probably the OS 10.5 version your're installing is not compatible or supported by the system motherboard of your computer model Apple Power Mac G5. per my research from Apple website herewith is their solution quote on what applicable OS to install for such model: "Power Mac G5 (Late 2005) and iMac G5 (iSight) models require Mac OS X 10.4.2 or later, you can t install Final Cut Pro 3.x or earlier versions on these computers. Final Cut Pro 3.x and earlier versions are not supported on any computer running Mac OS X 10.4". best regards
If your video card was not working correctly your problem would be evident in other applications as well, I suspect you have a software problem on the computer, most likely with the OS 10 software and possibly a conflict with the version of Quark you are running.
