Apple iPhone Smartphone Logo
Posted on Oct 24, 2009
No keyboard on iphone when Im in gmail
Go into compose new email on my iphone or reply/forward and the keyboard does not display.
The keyboard works with other apps notes etc
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2464
Points
20
I had the same issue and called Apple iPhone support. To fix it, I had to turn off my iPhone for a minute (like completely off where you slide it to power off rather than dimming it). Then when I reloaded it back up and opened my Gmail, it worked just fine. I know it seems like a simple fix but it worked for me so hopefully it helps you guys too!
Anonymous
Level 1:
  • Posted on Dec 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2464
Points
Have the same issue... do you already have a solution?
Anonymous
Level 1:
New Friend:
  • Posted on Dec 13, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2464
Points
Same issue anyone got a fix ??
How do i send an email to someone
Open your email program. Look for 'compose', 'create' or 'new email' and add the email address to the individual you want to send the mail to. Enter a subject. Write your text. Click on send, and you are done. Now you can wait to see what the reply is in the same email program.
If you need to respond back, just hit the reply button and enter your text. Once again hit send.
Mar 06, 2015 • gmail.com
I receive emails on my mac and some I forward to friends,but their unable to open them youtube etc and ask I send again but when I try I cannot open either. Please Help
Hi Richard. Thers a good chance you have mail preferences setup to compose new emails in "plain text". And/Or, "Use the same message format as the original message", meaning if you reply to someone who sent you an email that is in Rich Text Format, then your reply will be in Rich Text Format but, if they send you an email in Plain Text Format, then your reply, and possibly any forwarding will be sent in Plain Text also.
For website addresses to be "clickable links" in mail, you need to ensure all emails you send, forward, or reply are in Rich Text Format.
go to Mail... Preferences... then select the Composing tab and ensure Message Format is set to "Rich Text".
Further below in the same tab you will see "Responding" and a tick box for Use the same message format as the original message (Respond using Rich or Plain Text).
If you always want to respond or forward in Rich Text only and every time, then deselect that option.
All links should work and be clickable from then onwards.
You can highlight a non working website link in the email body, right click, then select "Link" then "Add Link" to make it clickable but, you will receive a notification about converting this message to rich text format?"
Basically, the links will not be clickable if you are setup to compose new emails in Plain Text. Nor will any replies or forwards you send that are changing to Plain Text to match the format received by you from others.
Always end, reply and forward in Rich Text Format
Hope that helps.
Regards
Paul
25295420-oyfl2tub33bpl2bhga1p2n43-3-0.png 25295420-oyfl2tub33bpl2bhga1p2n43-3-2.png 25295420-oyfl2tub33bpl2bhga1p2n43-3-5.png
1helpful
Unable to compose, reply, or forward in Yahoo Mail for the last 2-3 days
The inability to send, reply, or forward emails could be from a program that was installed on your computer that is now preventing the Yahoo! Mail Rich Text toolbar from launching properly. Try switching from "Rich Text" compose mode to "Plain Text" as a work around:
  1. Sign in to your Yahoo! Mail account.
  2. Click the New button to start a new email.
  3. To the far right of the "Subject" line click the "Plain Text link.
  4. Compose and send your email.
To make "Plain Text" your default when replying or forwarding, do this:
  2. Click "Options," then select "More Options" from the pull down arrow in the upper right corner of your Mail page.
  3. Select "General" from the list of options on the left side of the page.
  4. Check the box next to; When replying & forwarding Mark original message with > (plain text only).
  5. Click the "Save Changes" button in the upper left corner.
Aug 17, 2011 • Yahoo Mail
I can send emails but i can`t forward emails to my contacts
hi. before forwarding the email, try to make sure list of contacts in TO list. especially there is a open of composing for new one / reply and as well forward options. try to check it with adding from add list..
Dec 23, 2010 • Yahoo Mail
3answers
Iphone Mail Settings
You can keep it setup to the IMAP settings, Thou you need to on the Iphone and the Outlook tick the box that says keep a copy on the server.
2helpful
3answers
Can't compose,forward & delete email, can't log out
So far my ID message not open repeattedlycomming this page cannot be displayed why? please help me, I have many message in my ID mail
2answers
Can't delete email or compose or reply
my best suggestion is for you to forward all your mail from this account to another account (just create another yahoo account) and make sure spam filters are on the new account while you get yahoo to fix the problem. they will fix it since you have paid a subscription to it. the minimum they should do is forward ur mail for you.
ps don't forget to change the reply-to field to your email address.
good luck
smeags
3answers
Set up an email acct on iphone
Same problem I had.
You have to talk with your IT guy, or whoever sets up your email accounts. They need to change your mobile preferences to allow your email to be used on a mobile device.
Also, they can give you the correct settings for the incoming and outgoing server mailboxes (almost impossible to find on your own).
Outlook on the exchange server is compatible with iPhones through IMAP.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
