I have installed a new Kohler Toilet model # K 11473-0 Wellworth model. It splashes when you flush it because the water level in the toilet bowl is too low. There appears to be no method to addjust the water level and it also flushes too fast not allowing enough water for a complete flush! Home Depot had no answer to how to adjust the bowl water level and flush time. Please let me know how to adjust the flush time and bowl water level. Thanks Vince Iannucci at [email protected]
First, check that the tank itself fills to the proper level. Adjust the fill valve as needed with the screw to adjust the float. Then check if the hose from the fill valve to the flush valve is connected. The hose is connected to a small nozzle that supposed to restrict the flow, but not too much. Check if this piece and the hose is not clogged. Clean or replace as needed.
To maintain a good flush, keep the holes under the rim open (use a tiny screwdriver to ream the calcium out and also remove buildup inside the bottom front hole in the bowl that pushes water to the "exit" for a powerful purge. Again a small 4" long screw driver can chop away any buildup and smoother the surfaces. Hope that helps.
Flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
