Question about SanDisk Sansa e260 MP3 Player
I have a sansa e250 and I tried to format it but it was not possible. I get the Message load main image failed, switch to recovery Mode. I Enter recovery Mode, and a tried to format it but it says ist only 16mb of space, while the device can hold up to 4gb. Also when I turn it on again it displays the same message of load main image failed. Please assist me, thank you
Posted by veritorestre on
Joe Negus
    President:
  • SanDisk Expert
  • 652 Answers
Start the sansa updater, set sansa to recovery mode plug in to computer unplug when told sansa should restart
Posted on Nov 02, 2009
  • Joe Negus
    Joe Negus Nov 02, 2009
    Rate please
  • Joe Negus
    Reset All
    NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
    TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
    TO PERFORM THIS OPERATION!
    If your device freezes up press the Menu button and hold for 15 seconds.
    This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
    will be gone.....
    Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
How do i switch to recovery mode
put it in lock mode and hold the record button.
then connect the usb cable while still holding the rec button.
Jul 25, 2009 | SanDisk Sansa e250 MP3 Player
Load Main Image Failed Switch to Recovery mode
Hi
what do you mean your sansa is not opening?
Thanks!
Oct 23, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 mp3 player
remove ur batery and replace it or download the file archieve.exe and install audible folder.then u can switch on it.
Jul 03, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 ask me this
Solution:
1. Put Lock on.
2. Push and Hold Both Rec and Power buttons while the power is off.
Then message should show saying: " Welcome to Recovery Mode"
Mar 17, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed, Switch to recovery mode"
If it still plugs in and works properly, you can try to format it or try to update its firmware with the firmware updater that you can download from sandisk.com and then click on download.
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
Unable to recover my sansa
i guess you will have to reinstall the hole mp4
Jan 18, 2008 | SanDisk Sansa e250 MP3 Player
I have a problem with my sansa e250
Volume + while connecting to computer will send Windows into recovery mode
Dec 23, 2007 | SanDisk Sansa e250 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Muntejaya Ginting
Muntejaya Ginting
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
