Question about Toshiba 57H81 57" Rear Projection Television
I have a toshiba big screen tv we believe both convergents need to be replaced we do not have 300-365.00 to repair it . I know how to solder can I do it myself???? model#57H81
Posted by oldbluechevy on
Anonymous
  • 647 Answers
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Oct 24, 2009
I have a Toshiba 55H70 TV. Lately it has been having issues with the screen. The picture will go out and theres different color lines, if we turn it off or unplug it and plug it back in it comes back. we...
Sounds like possibly cold solder connections on the convergence IC's I believe there are 3 in your tv. They are easy to spot big black IC's that have STK392-xxx stamped on them.. If your lucky you can solder the connections and be back in business. Sometimes because of the bad connections left unrepaired it will cause the ic's to fail then they would need replacing. If you have soldering skills you might try yourself. Be careful and make sure its unplugged. If you arent skilled at soldering I wouldnt recommend even trying it.
Oct 17, 2010 | Toshiba 55H70 55" Rear Projection...
Multi- color bands - twisting wave pattern cross the middle of screen and can not get image to lock -flickers both horizonal andf vertical. Would this be the same 2 IC chips- last time i had this problem...
Ur tv have convergence problems,it dead.U must have soldering tools,solders and know how to solders to fix convergence problems.U must replaced 2 STk convergence ICS,and some or all it resistors.Tries websites Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
May 11, 2010 | Toshiba 50H72 50" Rear Projection...
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
Wavey distorted screen
Ur tv convergence are dead.U must know how to solders?U must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 02, 2010 | Toshiba 42H83 42" Rear Projection...
Toshiba model 42H81 projection tv receiving blue and yellow shadows on screen.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Toshiba 42H81 42" Rear Projection...
My screen seems misaligned, the colors dont seem to be lining up properly how do i fix it?
Convergence it dead,must buy a convergence kit replaced what in that kit.U know how to solders?Tries these websites Tv repair World.com,Tv repair Kits.
Oct 27, 2009 | Toshiba 42H83 42" Rear Projection...
Convergence in Toshiba 43a62 projection tv
its not likely to have come un soldered or loose, a lot of times when you move a big screen they have to be reconverged. not because of damage but because of the move in general...i would call a shop and have them come out and re converge it. that what it will take to get it done right
Feb 26, 2009 | Toshiba 43A62 43" Rear Projection...
Toshiba big screen The tv is like double exposed . I have a toshiba big screen tv and I have double images in red and green. How do I fix this problem?
This is likely your convergence ICs(chips). If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
my company charges $300-400 for the full repair (replacing ICs, full realignment plus cleaning)
if you can find a company that will resolder for you, it could cost $100-200 maybe. if you are a handy person with soldering skills, you could repair yourself. i can instruct if needed, but convergence IC soldering requires decent soldering skills. you will find the ICs on the largest heatsink in the tv. the part number starts with STK. if you replace them, check the resistors in front of them and replace accordingly. most toshiba will blow up to 3 fuses (f850, f851, f852)
Dec 08, 2008 | Televison & Video
Big screen TV
chances are the repair man wanted to sell you a whole board because with mitsubishis this problem is amost always the convergence ic's also in that model very seldom the resistors burn out in that unit its almost always the IC's that do that. I looked for you information you have an old chassis but I think its similar to the Vz2 I believe you need IC number STK391-020 thats based on theVz2 chassis but pls double check and you need 2 of them you can also save yourself if you know how to solder a lot of money by replacing them yourself its about a 45min job if I can help you any further pls let me know or if you would like a link where you can buy your parts very reasonable with tech online support let me know
May 08, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Convergance/coaxial cables
Check any / all soldered in micro fuses...F851,F852,etc.
Note:read my Powered Products>View all>Toshiba>convergence issues .........? What quality IC's did you use and what price did
you pay ?............................T.
Mar 12, 2008 | Toshiba 50HX81 50" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
