Question about Sylvania LD370SS8 37 in. LCD Television
Sylvania model number LC370SS8M will not respond to Verison Fious remote.
Posted by bboz57 on
Anonymous
    New Friend:
My Sylvania Lc370ss8ms has blue vertical lines and will not stay on.
Posted on Feb 12, 2011
What is the code for my sylvania television
Do you mean codes for adding your Sylvania television to a multifunction or universal remote? Without the model number it is difficult to narrow down but you can try the following Sylvania codes and see if one provides the functionality you need.
0020
0030
0054
0096
0381
If you can provide more information about the specific model name and/or model number of your television that will help. Additionally, if you are using a multifunction remote provide the name and model of that as well. Good luck!
Feb 28, 2015 | Sylvania Televison & Video
Direct TV remote
I think you mean Hughs when you're referring to your direct Tv remote? And you want that remote to turn on/off your Sylvania Tv, right?
I'd need to know the Hughs model number on the remote to know if it's a four or five digit code requirement. But here's a site that might help. http://www.remotecodelist.com/remotes/
Scroll down to Hughs and that link should take you to the DTV site where they have a wealth of info regarding codes. Find your model number remote control and you should have a list of possible codes to try.
If all this doesn't work let me know and I'll research sme more.
Good Luck!
Bill
Nov 25, 2007 | Sylvania SH50102 LCD Remote Control
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
I'm using a ge universal remote and cnnot get the sylania model 6513 DF to work
Hello
You haven't described anything about the model number of GE remote. Eventhough it is universal remote, it will have a model number. Model number is necessary for us to give you correct codes. I hereby give you code for Sylvania combo. Check it with.
0456
The code for Sylvania TV/DVD combo with GE RM 24912 universal remote is:
456
Check this code [456] with your present GE remote. Sometimes it may match. OK.
Jun 04, 2011 | Sylvania 6513DF 13" TV/DVD
I need a code to my universal remote for model 6420FF Sylvania Tv
G'Day,
The code you require depends on the manufacturer of the remote. Do you have the model number for the remote there please.
regards robotek
Aug 31, 2010 | Sylvania Televison & Video
I need remote control codes for a Sylvania VCR/DVD
hi! i have here a couple of codes for your sylvania DVD/VCR just try them, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095. hope this helps!!!! goodluck!!!
Mar 18, 2010 | Sylvania (SRDD495) DVD Player/VCR
The television has stopped responding to its remote and a cable remote.
Hello SKrokau:
Have the IR sensor (Infared Sensor) replaced in this model. It is a common failue for Sylvania televisions. The IR sensor is the device used to receive commands from the remote and relay the commands to the microprocessor for processing. The sensor is very inexpensive and the total to repair should not cost you more then (FYI) $80.00 for parts and labor.
Have a Happy Holiday!
Nov 22, 2009 | Sylvania SRT2232S 32" TV
I have a sylvania flat screen dvd combo looking for remote code for universal remote model number ld320ss8a
Here are all of the possible remote codes for Sylvania.
006,007,010,011,013,016,027,033,035,
043,049,066,087,089
Good Luck!
Oct 11, 2009 | Sylvania LC320SS8 32 in. LCD Television
Rcr312w universal remote control, I need codes for sylvania tv/vh
Sorry it took so long to respond to you request for help.[ Sylvania TV Code-1251, VCR Code-2154 ] These are the listed code for your model remote control and the Sylvania television and vcr combination unit. I hope this information solves you problem of needing codes to use your remote control with you television and vcr combination unit. Thank you for using FixYa and have a nice day.
Feb 22, 2009 | RCA 3-Device Universal Remote with...
Programming it to a Sylvanvia TV model 6420FF
Hello thank you for choosing FixYa.com for your answer my name is David.
I have found a list of codes for the rcu600m for the sylvania tv here they are
Code For Model RCU600M
Code 004 for Sylvania TV Code 006 for Sylvania TV Code 008 for Sylvania TV Code 019 for Sylvania TV Code 062 for Sylvania TV Code 068 for Sylvania TV Code 069 for Sylvania TV Code 075 for Sylvania TV Code 076 for Sylvania TV Code 077 for Sylvania TV Code 088 for Sylvania TV Code 116 for Sylvania TV Code 130 for Sylvania TV Code 132 for Sylvania TV Code 134 for Sylvania TV Code 161 for Sylvania TV Code 183 for Sylvania TV Code 196 for Sylvania TV Code 353 for Sylvania TV Thank you again for choosing Fixya.com
Nov 08, 2008 | RCA RCU600M Remote Control
Sylvania LD370SS8 37 in. LCD Television Logo
134 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
