Question about Casio CW-75 Thermal Label Printer
I cannot install Casio CW75 printer to my pc
I cannot install the above printer to my pc running Windows Vista 64 bit operating system - can you suggest anything please?
Posted by j_g_price on
Anonymous
    New Friend:
I figured it out! I created a Windows XP Virtual Machine and installed the Casio CW50 Vista 32 Bit Drivers. Then:
1. Press F8 while booting Win 64 and put win64 in “disable driver signature enforcement mode”.
2. I had already installed the 32 bit Vista version in Win64, but the drivers didn’t install.
3. Tried again and they still didn’t install.
4. I manually copied the driver from the VM to Win64 and exported the proper registry key.
5. I imported the registry key into Win64.
6. It works great. Since I don’t used it very often, it’s not a big deal to press F8 every now and then.
Hope this helps,
Roscoe
Posted on Mar 10, 2010
Anonymous
    President:
  • 1,865 Answers
You can either buy a new printer, utilize the dual OS feature and install an OS compatible with this printer
Posted on Oct 24, 2009
Lexmark driver 517 for windows 7
Use the Vista driver in Windows 7. First, check if your system is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download the corresponding printer driver for your operating system:- Lexmark Z517 Driver for Vista/Windows 7 32-bit- Lexmark Z517 Driver for Vista/Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation.
OS is windows 7 and i want to connect lexmark p4350 inkjet printer
Use the Lexmark P4350 printer driver for Vista OS on Windows 7. But first, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download and install the printer driver on your computer:- Lexmark P4350 Printer Driver for Vista 32-bit or Windows 7 32-bit- Lexmark P4350 Printer Driver for Vista 64-bit or Windows 7 64-bit
I hope this helps. Thanks.
I have a pc with a Windows 7 home premium and i have too (formerly) a LexmarkZ 601. I need drivers for my Lexmark. Thanks for help.
Please check if your Windows 7 is running on 32-bit or 64-bit operating system. Go to Start menu -> right-click on Computer -> Properties. Take note of the System Type.
Now, there's Z601 driver specific for Windows 7, however, the vista drivers work. Download the compatible driver for your operating system using the links below:
- Lexmark Z601 Driver for Vista 32-bit / Win 7 32-bit - Lexmark Z601 Driver for Vista 64-bit / Win 7 64-bit
Hope this helps. Thanks.
2answers
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
40helpful
2answers
INSTALLATION OF LEXMARK X5250 PRINTER ON WINDOWS 7
Hi, Lexmark printer drivers can be found on this site: Driver Update Software for XP Vista 7 8. Have a nice day
Thomas
1helpful
Cannot download or install kodak esp3 aio drivers or software
either you have 64 bit op system or you dowmloaded the wrong driver on accident.
if this information helps please use fixa when rating. thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
3answers
HP OJ 5610 Drivers-? Can not install printer.
In this case, there's no mystery as to the cause of the problem. You will be unable to use this printer with your operating system because there are no existing print drivers that work with 64 bit Vista. Your printer will work with Windows 98, Windows 2000, and Windows XP, but not with Vista at all.
You have only two options...use a different HP printer that will work with Vista, or get a PC that has one of the supported operating systems on it and connect your current printer to that PC.
Sorry. I know this isn't the answer you were looking for, but that's the best I can do until the proper drivers become available.
Casio CW-75 Thermal Label Printer Logo
Top Casio Office Equipment & Supplies Experts
k24674
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
