Question about HP LaserJet 3055 All-In-One Printer
HOW TO SET FAX IN HP LESERJET PRINTER 3055 - HP LaserJet 3055 All-In-One Printer
Posted by msg2tarun on
Tim Swiercinsky
    President:
  • 1,126 Answers
Pages 67 thru 117 covers all fax functions and features of your HP Laserjet 3055 in this users guide. Hope this helps.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00495173/c00495173.pdf
Posted on Oct 24, 2009
I have Hp Laser jet 3055 can install only the printer under windows 7, but unable to install the fax facility.Please help.
Then please navigate to www.hp.com, click on support and type the model details e.g HP Laserjet 3055 all in one printer and select your computer operating system type to download the full drive for all your printer facilities.
Thanks
May 18, 2011 | HP LaserJet 3055 All-In-One Printer
How can we save our scan file in pdf formate from HP Leserjet 3055 ?
You need to install a PDF writer program first. There arequite a few freeware PDF writer programs on the Internet you can download onesuch as CutePDF.
Scan your document the click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. http://www.cutepdf.com/
Feb 21, 2011 | HP LaserJet 3055 All-In-One Printer
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Mar 13, 2010 | HP LaserJet 3055 All-In-One Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
3055 fax not working, sendng or receiving directly
Below is a link to an HP tech site. They helped me with MY hp all-in-one. It turned out I needed to download a different driver from HP's tech website (the download is free) and that is probably what you will be doing, also. God luck.
Jul 08, 2009 | HP LaserJet 3055 All-In-One Printer
How to connect the printer wireless
I don't think the HP 3055 has built in wireless capabilities. It does however have a built in 10/100 Base-T TCP/IP networking with 1 RJ-45 port, Hi-Speed USB 2.0 port, RJ-11 fax port, RJ-11 line-out telephone port. You should be able to connect directly into your hub or router and access the printer through a wireless router. You can get more information on set up at the link below.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/18972-18972-3328064-12004-3328082-1161389.html
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 Lasrjet
receive set to manual set to automatic
Dec 04, 2008 | HP LaserJet 3055 All-In-One Printer
HP laser jet 3055 not doing net work printing
Has a printer cartidge loaded but says that does not
Oct 17, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
273 people viewed this question
Ekse
efs_perpends
efs_perpends
