Question about GE (PSS26MSRSS) Side by Side Refrigerator
Every few weeks the ice in my freezer melts. It
Every few weeks the ice in my freezer melts. It appears there is a problem with my defrost cycle. What could it be?
Posted by nordygirl765 on
  • nordygirl765 Oct 24, 2009
    The ice cubes melt into a 8x8 pan we have put under the ice maker. Last night we went to bed and the ice was frozen. This morning we realized the pan was full of water. The melted ice has dripped onto food packages and begun to reform ice. There is very little seal on the freezer door. The freezer is not making any noises now, but I have hear louder than usual noises in the past. There are 2 non movable vents high and low in the freezer. We have oticed things in the bottom drawer of the refrigerator have froze.
  • gdoliver Oct 30, 2009
    i have the same problem with my ge side by side. the model is PSH25sgsa. thinking it is related to control board at this point.
william bennett
  • 945 Answers
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Posted on Oct 24, 2009
macgivor
  • 234 Answers
Do you mean ice cubes melting or ice build-up on product or back wall ? Is the refrigerator side always very cold or does it also go through up & down temp every few weeks ?
1st, try reducing the air flow between freez & frig compartments either by changing temp settings or opening/closing the port door (if equiped) in the wall between frig & freez; htis port may be at top or at bottom of wall.
2nd, does the fan motor in the freez section make noise or occational noise ? Thid would indicate that it is notmoving at full speed and the air movement is slow----thus causing colder/warmer periods.
3rd, check the coil (condensor coil) under the frig; if it is loaded with dust and dirt then the frig cannot get rid of the heat build-up and you'll have these temp variation periods, also you are wasting electricity with a dirty coil. Good luck, Macgivor
  • macgivor Oct 25, 2009
    You pose an additional piece of the puzzle when you say the door gasket (seal) is very poor; wasting energy and causing unit to try and keep-up with the cold requirements.
    Is this summertime only or throughout the year problem? Also, you do not say if there is sweat on the outside around the door openings. Your stating the problem re-occurs every few weeks is also puzzling since this aspect does not fit too well most problems associated with freezers or defrost system malfunctions. Maybe you really need a professional to personally view your unit and diagnose it. Pay for the service visit, but fix the problem yourself.
    hope this final prognosis gets you results. Sincerely, Macgivor
Water appearing on the bottom
More than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. Also note on the maytags these days they put a rubber piece called a duck bill on the bottom half of the drain which will also cause this over time. To access this piece you'll have to pull the machine from the wall and remove the lower panel and find the plastic drain and remove the duck bill
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 09, 2012 | Woods Upright Freezer MU07W
Water is pooling under the veg/fruit drawers..cant tell where its from. Freezer temp is uneffected, temp appears fine, no condensation anywhere on refrig or contents...The first I noticed it was a week...
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
Feb 17, 2011 | GE J Series 20.6 cu. ft. Top Freezer...
Where is defrost timer on amana arrccb
The ice in the ice tray freeze together as if they melted for a time then refreeze. It appears to maybe be a defrost problem. Can I adjust the defrost cycle on My Amana Bottom Freezer Refrig?
Nov 01, 2010 | Amana ARB224RCC Bottom Freezer...
Refrigerator seems to just turn off for a day or so every two or three weeks and all the freezer items melt. Kicks back on after some time and works fine for another 2-3 weeks then repeats. Have unplugged...
Most Refrigerators have a defrost timer which cycles every couple of weeks, typically for several hours, in order to let any residual ice melt from the cooling system. If yours cycles long enough for the freezer items to melt, it should be replaced.
Nov 02, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Appears to go into an extended defrost cycle.
Sounds like your freezer has a bad defrost thermostat ( bimetal ) or bad #4 and/or #5 thermistor . This bimetal , has a high temp rating of 140 degrees , which means , when it gets to 140 behind the panel , it will cut off the defrost heater , to keep ice and food from thawing . The thermistors , tell the main control board the temps , and it decides when to restart the cooling process . I would check the thermistors by the digital controls , in the test mode , or have a technician check them for you .
Sep 12, 2009 | GE Refrigerators
Model #PSS26PSSA SS Freezer frequently defrosts and refreezes. When this occurs, the entire ice bin melts into the freezer compartment and refreezes in puddles. Is this a common issue with this model and...
Absolutely not ! There are two types of defrost systems - timer (which relies on compressor run time) and adaptive (newer models) which relies on sensors and an electronic control and will defrost as needed...... During a defrost cycle your comrpessor and evap fan should be off, everything off - and no, a defrost cycle will NOT thaw your food in the freezer, not even your ice should melt ! To me this sounds like a defrost control problem - First thing service should check is your defrost timer and its components (control board, limiter, defrost thermostat, etc.) something is definately wrong.
Now with the advice above I am assuming that before the defrost cycle kicks in your freezer temp was in the normal range 10F and colder (0F is optimal) and refrigerator section cooler than 40F (optimal 34F). If so, then you should not have melting ICE in your freezer.
Aug 24, 2009 | GE Refrigerators
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Water inside bottom of freezer after defrost cycle
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Tray Freezes & ice builds up around internal workings of ice cube holder
Check and make sure you door seal is tight. Take a dollar bill and place it between the door jam and gasket, close the door and then pull the bill slowly out. It should be rather tight all the way around. So you will have to do several checks all the way around the door. If you have a bad spot call and have them either replace the gasket or adjust the door.The other thing you can do (I have found most if not all manufacturers require this) empty your ice maker once a week. The problem comes from your refer being a self defrost. There is a heater coil that gets as hot as a range element to defrost the evap coil. It is the defrost cycle that causes the ice to melt down a bit. And the defrost cycles every 12 to 24 hours causing the cubes on top to melt down some. So as your bucket fills whatever was on top melts a bit and by the time you are ready to use several layers may be melted causing them to stick together.
Jun 07, 2007 | KitchenAid Superba Architect KSCS25INSS...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
593 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
