Question about Vivitar 283 Flash
What is the trigger voltage for a 283 bought in 1996 and is it safe to use on a nikon d80
Posted by davesmith56 on
Anonymous
  • 149 Answers
Take multimeter and see the voltage must be not more then 5 to 6 only you can check the voltage near the hot shoe or cord
Posted on Oct 28, 2009
The MENU button in my Nikon D80 is not working. When I push the button, the screen remains blank. Before this happened, I placed an external flash on the hot shoe, but it did not flash.
If you attempted to use an external flash with an incompatible trigger voltage, it has probably damaged the electronics in the camera.
May 15, 2017 | Nikon Cameras
I have vivitar 2800 flash for my pentax can i use it with Nikon D70s
If there is a D after the 2800 you're probably safe. The trigger voltage is 8 volts so to be sure, find out what the upper limit of trigger voltage the camera can safely handle. If there is no D designation in the model number it will definitely fry the Nikon
Mar 14, 2013 | Vivitar 283 Flash
I now have a Nikon D80. I have a National Flashgun Model PE300SWG Can you advise me if this 'gun is safe to use with the D80?Nikon tell me that as long as the trigger flash voltage is o--250volts it is...
A flash trigger voltage in the 250V range is fine for most film cameras, but not for most digital cameras. The PE-300 has a trigger voltage in the 33V range, which I (and most others) would consider much too high for the D80.
BTW, "National" is a brand name used by Panasonic.
Oct 21, 2011 | Panasonic Cameras
Hi I've just aquired a monster PE-3550 from an attic sale Will this work on modern day dig slr's ? I have a nikon D80 & a D300 thanks Phil email [email protected]
The National/Panasonic PE-3550 has a trigger voltage of 32V. The 1992 ISO standard states cameras should be able to handle up to 24V. Some people within Nikon claim their cameras can only handle up to 12V. Either way, I wouldn't use a PE-3550 with a Nikon dSLR.
At least not directly. You can use something like a Wein Safe-Sync to isolate the two.
Feb 11, 2010 | Canon PowerShot EOS D60 Digital Camera
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
Vivitar 283 with new Nikon Digital camera
the nikon D80 has a 250 volts safe range and i have the same issue but readin on the internet i learned that yo can now the voltage of your flash with a voltage metter ond the hot soe.
Vivitar 283 has diferent ranges of voltages depending on the year of fabrication so older ones can achieve 300 volts and earlier have 230 volts so the best is to get a vivitar 285hv for about 75dollars or a safe sync for about 55dollars, you can find all on ebay or other brouser the safe sync converts up to 400 volts to a safe 6 volts that are yust the normal voltage for digital flashes.
Jan 06, 2009 | Vivitar 283 Flash
Nikon D80. Vivitar 4600 Flash unit
That particular unit is probably not a good choice for the D80 because the trigger voltage (the electricity which flows from the flash through the camera circuits to fire the flash) is 19.5 volts, according to http://www.botzilla.com/photo/strobeVolts.html - this could possibly damage your camera electronics.
You don't have to stick with Nikon brand Speedlights, but get a modern flash which says it is I-TTL compatible for Nikon.
Jan 01, 2009 | Vivitar 850AF for Nikon TTL Flash
Vivatar 283 and Nikon D70s
The Vivitar 283 was manufactured in China & Japan over a number of years & the specifications did change over this period.
The older Vivitar flashes had a voltage on the shoe which could reach 150 volts whilst the later ones had voltages of only 5 to 9 volts.
If you have, or can get hold of, a small voltmeter then you can measure this voltage.
Turn on your flash & let the unit charge up to 'ready' & connect the meter between the contact in the centre of the shoe & the little contact tucked away in the lip of the shoe. (DC volts not AC) There is no danger to you in doing this!
This should tell the voltage on the shoe of your unit & if it is 15 volts or less, it will be fine with your digital Nikon camera. If more than 15 volts than best not to use it.
Hope this is of some help!
Mar 10, 2008 | Vivitar 283 Flash
Vivitar 283 Flash Logo
137 people viewed this question
Top Vivitar Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Barbat Nae
Barbat Nae
Lee Hodgson
Lee Hodgson
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
