SOURCE: Blank screen
Hi: Check and see if there is an X as in escape out of the Menu Mode. If there is no X,then look fo OK. Good Luck. zeffy57.
SOURCE: sony handycam DCR-HC20 Screen blank
the ccd image sensor of your camera is defective that why is no image you see..better go to sony service center for replacement of the sensor...
SOURCE: HANDY CAM LCD SCREEN BLANK
Inside the door hinge area is a small switch that normally would turn off the viewfinder and turn on the LCD panel. THat switch could be defective or mechanically not being switched. WIthout opening up the unit, I can not tell specifically. This shouldbe a simple repair for any shop that repairs cameras.
Dan
SOURCE: Sony DCR-SR62 screen rolls continuously
HAd the same
It's a flex wire connecting LCD with camcorder. got from the repair shop. did it by miself workes like new. it'very common in this kind of sony.
