Question about Epson STYLUS R230 InkJet Photo Printer
Two Red lights blinking constantly. unable to
Epson -R 230 desktop printer. Two Red lights blinking constantly on the control panel (beside main switch). unable to print.
Posted by solomon_rajs on
Anonymous
    New Friend:
Posted on Nov 07, 2009
Anonymous
    New Friend:
I have canno iP1900, Problem,, mya printer can't be stoped.. lead on continu.. can't be stoped...
Posted on Nov 02, 2009
My epson stylus R230m printer is blinking the two red light what will i do
If blink is alternative, jast download service tool for epson e 230 and follow the given instruction that are inside the file web address:tricks-collections.com/resetter-epson-stylus-photo-r220-and-r230/
if blink same time: it,s a fatal error. it could be something wrong with the carrage or board or encoder belt
Thank you.
Feb 28, 2011 | Epson STYLUS R230 InkJet Photo Printer
2 red lights are blinking!!!!!
is both the light blink the same time or blink alternate ? if blink the same time, it's probably a fatal error..
if blink alternately then the waste ink counter need to be reset and the waste ink pad need to be replaced.
Jul 18, 2010 | Epson RX620 All-In-One InkJet Photo...
My both red light is blinking continuously what i do help me
both light are blinking at the same time or blinking alternatively ?
if both blinking same time, it's a fatal error.. means it could be something wrong with the carriage or board or encoder belt...
if the light blink alternatively, it means the waste ink counter need to be reset and ink pad need to be replaced.
May 26, 2010 | Epson Stylus Photo R200 InkJet Printer
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Printer EPSON R 230
problem about flashing red is solved using SSC ver 4.20 to solve the waste ink.
http://www.ssclg.com/epsone.shtml
Oct 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
What should I do, my Epson stylus R230 is not printing and the 2 red lights are blinking? What button on the SSC utility service should i click on?
Run SSC. Menu Configuration. Select installed printer. Select printer mode to Epson R220/230. Close dialog box by clicking cross sign at top right of dialog box. Icon will show at bottom right of dekstop. Right click, select protection counter. Show current value for checking waste ink counter. Click Reset protection counter. Turn off printer. Turn on again. Usually SSC doesn't work at Vista.
Oct 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printer will not print
Which of the two red lights is on? If it's the red paper light, it simply thinks it's out of paper. Make sure your stack of paper is properly seated in the Automatic Sheet Feeder. If it is the red ink light, it means that during a print task (printing, head cleaning, ink charging), an empty cartridge was detected. Go through the cartridge replacement procedure as described in your User Manual. If you don't have one, see:
http://files.support.epson.com/htmldocs/sc88__/sc88__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
"Replacing an Ink Cartridge.
If this information doesn't answer your question, please post a new comment with more information on what you want.
If this information was a help, please rate it.
Jan 25, 2009 | Epson Stylus C88 InkJet Photo Printer
How to?
that's in the settings panel, under printer settings..set it for greyscale
Aug 03, 2008 | Epson Stylus RX580 InkJet Photo Printer
Printing Problems
In Windows 98/ME/2000:
1. Go to START, SETTINGS, PRINTERS.
2. RIGHT CLICK on your Epson printer name; left click on PROPERTIES.(PRINTING PREFERENCES in Windows 2000).
3. Go to the MAIN tab.
4. Place a check beside BLACK INK ONLY.
5. Click APPLY then OK.
In Windows XP:
1. Go to START, CONTROL PANEL, PRINTERS AND OTHER HARDWARE or PRINTERS AND FAXES. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear).
2. RIGHT CLICK on your Epson printer name; left click PRINTING PREFERENCES.
3. On the MAIN tab.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
Dec 28, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson R 230...is trouble......
This suggests a general error.
Switch off remove paper
Leave for 10 minutes
switch on and start over
Does it work now?
No?
Then it needs the counters reset
download the Epson utility from www.ssclg.com
load it
set it to your printer
right click ther tool bar icon
use the reset featir
or go to
www.fixyourownprinter.com and check out your printer in the Forum.
Dec 24, 2007 | Epson Stylus RX425 Multifunction...
Epson STYLUS R230 InkJet Photo Printer Logo
613 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
