Question about UTStarcom CDM8932 Cellular Phone
I have a utstarcom um100c modem and a notebook. How can I install the software on my notebook without the use of a cd driver?
Posted by adrianveidto on
Utstarcom um100c software for windows 7
for your download click htt
This device will work on win7, no problem. You'll need the install disc or the software.
UM100 win7 64bit
1.Double-click the quicklinkmobile.exe application from cricket. It will unpack a folder with the installation files in the same folder the quicklinkmobile.exe app is residing.
2.Go in that folder and click on start.exe, then click on install quick link mobile. Go through the normal setup as you normally would.
3.Once it finishes installing, connect your UM100 UTStarcom modem on a free USB Port. Don't open the Cricket Wireless application just yet.
4. Go to start menu, right click on Computer and select properties. Then click on device manager on the left. You will find the UM100 modem has an exclamation point on it.
5.Right click it and select update driver. Select "Browse mycomputer for driver" Option at the bottom. Click on Browse to select a driver from a location, then navigate to your root drive (usually C: and sometimes D then to Program Files (x86)/Cricket/Quick Link Mobile/System
6.Make sure you navigate to this cricket wireless installation folder. It should be in C:\Program Files (x86)\Cricket\QuickLink Mobile\System. Once you find it click ok. Make sure "Include subfolders" is selected under it. Click on "next" and now it will install the driver.
7. After it installs, it will create two more Unknown devices with exclamation points. Wait a couple of minutes for the system to finish up installing that one before you continue with this instructions.
8. Now repeat steps 5 and 6 above for each of the two unknown devices until there are no more devices with exclamation points in device manager.
9. Now open Up Cricket Wireless application on your desktop or start menu, and continue with the normal modem activation of the wizard that appears. That's it! It will now detect the modem and activate it. Allowing you to use it.
10. Go and find whoever said you couldn't use this modem on 64-bit systems and punch them in the face.
11. Call me so I can punch them in the face again.
12. Enjoy your newly installed UTStarcom UM100 cricket modem on your 64 bit system. Ask Cricket to update their website with this information. Punch them in the face too for the sake of completeness
Read more: http://www.cricketusers.com/cricket-mobile-broadband-devices/20339-utstarcom-um100c.html#ixzz22FHP7OMr
hope this helps
Jul 22, 2012 | Sabrent USB 2.0 NT-USB20 Ethernet Adapter
Need a windows 7 driver for utstarcom UM100c
It looks like Cricket doesn't really support this for windows 7. But the following site has some information from other owners of this modem that seem to have a working solution there. You might want to check it out.
http://forums.techguy.org/windows-7/881565-utstarcom-um100c-windows-7-a.html
Mar 16, 2010 | Computers & Internet
Utstarcom um100c modem drivers for windows 7
1. Start the install process as normal, you will get to the section that asks you to plug in the um100c.
Windows will not automatically install these drivers for you.
2. Leave the setup program running and open up Device Manager
3. Find UTStarcom UM100C under unknown devices.
4. Manually search for the driver in "C:\Program Files (x86)\Cricket\QuickLink Mobile\System\driver".
After it installs there will be two more unknown devices in Device Manager. Repeat the manual driver lookup in the same location to install them.
5. After that go back to the setup program, you should now be able to click on Next to finish it.
Jan 01, 2010 | Computers & Internet
Trying to install the UTStarcom UM150 on HP Pavilion dv7-2277cl
well what os are you using currently for example windows 7 windows 10 etc
you can find out what os u are using by typing winver at the run or command line in the start menu
Jan 02, 2018 | HP Pavillion DV6227 Notebook
Signal loss
You may be far from the modem. Try getting closer. Or it can be of interference. Is there a wireless phone in your area? try removing that.
Jun 14, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Want to install modem ambien model md5628d-l-b
i have modem without its sowftwer cd modem is ambient model no on its chip
Apr 26, 2009 | Computers & Internet
WirelessModem
First to clarify; is this a WIRELESS ROUTER?
If it is OK, there are also LAN/ethernet outputs on it as well.
DESKTOP COMPUTERS do not typically contain Wi-Fi apadters or 'antenna', these are in most all laptops made these days.
If you have a wireless Wi-Fi Router then it should be fairly straitforward to connect laptops (Start Menu>Connect To, in Windows)
You may have to either HARD WIRE (ethernet line) or buy an internal Wi-Fi or USB Wi-Fi Adapter/antenna. If it's a fairly recent wireless router this becomes fairly straight forward after that.
Jan 05, 2009 | Computers & Internet
Connecting my xbox to internet with utstarcom um100c modem on pc
You are not going to like the answer I have for you. Forget connecting wireless with X-box. Purchase a router with an Ethernet port. I do this for a living and run in to this problem all the time. Trust me, hard wire with X-box is the way to go. A Lynksys router is a good router and is also VERY user friendly.
Dec 31, 2008 | Computers & Internet
UTStarcom CDM8932 Cellular Phone Logo
181 people viewed this question
Top UTStarcom Cell Phones Experts
Marvin
Marvin
L Vincent Testa
L Vincent Testa
Andrew Taylor
Andrew Taylor
Are you an UTStarcom Cell Phone Expert? Answer questions, earn points and help others
