I have a 32'' Vizio model # VX32L and have no picture. The sound is fine, Ive checked the input and its right, I left it unplugged for a while and plugged it back in to reset, but no change. On some chanels the picture pops in now and then, but its not clear and only stays on for a fraction of a second. Would like to know if its fixable at a reasonable cost. Thanks
Hi my name is Roety,
I can help you with your issue ,
Voltage checks would be needed to locate the bad board, Try rebooting everything by unplugging from AC for 30 seconds. If there is no TV menu , no backlight.
It probably a bad panel and not worth repairing.
If there is a TV menu try using the component or HDMI inputs, if its works you need a mainboard, but can use the TV on those inputs instead of fixing it.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I had the same problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make
sure the backlight still works. I ordered a new "main PCB" from
tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine. I
used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272
2174 or it was 3632 0212 0150. Check your circuit and see if any of
those numbers match up.
used
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com
disconnected the old one, put in a new one and now it works fine. I used
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com
used
80% of TVs are having this same problem in different brands.
I'm sure Carlos meant well. If you took it to someone to have it fixed, then yes, it would be cheaper to by a new TV. ( Labor + Part )
But, if you can repair your TV yourself for less than a $100 vs buying a new TV for over $450, would it be worth it? ( Part alone )
If you or someone you know can replace a whole ciruit board, then it can be fixed.
Here's a web site to get the replacement board: http://www.shopjimmy.com/catalogsearch/result/?q=vx32l+back+light
You'll just need to find the right one by looking at yours. Your backlight board will have letters & numbers on it for a board model#. It should be easy to find one and replace it.
