D-Link AirPlus DI-614+ Wireless Router Logo
Posted on Oct 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
D-Link DI-614+ is causing Comcast Internet to boot wired user off internet every 45 minutes. It is also asking Iphone wireless user to put the password in every time Iphone user connects.Problems only recently started after years of easy use.
Prashant M
Level 3:
  • Master 2,278 Answers
  • Posted on Oct 25, 2009
Prashant M
Master
Level 3:
Answers
2278
Questions
Helped
978031
Points
6246
YOU CAN TRY TO UPGRADE THE FIRMWARE OF THE ROUTER.
YOU WILL NEED TO DOWNLOAD THE LATEST FIRMWARE FROM THE MANUFACTURER'S WEBSITE.
DOWNLOAD THE CORRECT FIRMWARE FOR THE CORRECT MODEL NUMBER AND THE VERSION NUMBER
CLICK HERE FOR MORE INFO
1helpful
Password protect wireless access
You'll need to access the administrator web page for your router, and then set a security key (password) for wireless users.
For step-by-step instructions for setting up security on the D-Link DI-614 router, see:
http://technicallyeasy.net/2010/10/how-to-secure-d-link-di-614-wireless-router/
2answers
PASSPHRASE
log onto the router... put in address bar in Internet explorer 192.168.1.1 and put admin as the user and password or admin as the password. you should be able to see the passphrase and network keys under the wireless section.
I have a d link di-524 wont work with comcast
how is your comcast connected to di-524?
make sure you have wireless enabled in router config.
type in to your web browser 192.168.0.1
login should be admin
password leave blank unless you have set one
then go to wireless section and check if it's enabled etc.
1helpful
How (or whether) to configure dlink 614 as a wireless access poin
go to this link and read the manual.
You may require a firmware upgrade also.
Thanks
Please rate the answer if it was helpful to u
Good Luck
7helpful
2answers
How to lock my router so neghbours cant connect
Follow the instructions on this D-Link page (it shows DI-614, but it is the same procedure for your model):
http://support.dlink.com/faq/view.asp?prod_id=1055
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Other computer won't connect wirelessly
Comcast is apparently weeding out multiple connections through routers. They want you to pay extra for their wireless router and pay an extra $5 a month too.
Current dlink basic want to use dling DI 514
If you want to use your former router, you just have to connect the previous router in between your modem and computer. Try turning off all the devices (modem, router and computer) for 2 minutes. Then turn on the modem first, wait for the lights to be stable then turn on the router. When the router lights are okay that is the time that you can turn on the computer and check the internet connection.
If the Internet connection still has not come back, you will have to reconfigure it for Comcast connection. You can try using the setup CD or access the setup wizard using 192.168.0.1. User name is admin and leave the password empty then run the wizard.
D-Link 614 Plus
You need to do some reconfiguration on your router by using the setup cd or by manually configuring it using the user interface of the router.
2answers
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
