It was working great..then I was getting purple images now and then....and now I get no image..nor will it display the pics on the screen. I charged the battery and the memory card is empty..and good size. did I push a wrong button? Been thru the menu...
SOURCE: Err CF
TRy and reformat the CF card through the camera. Youll lose the pics for sure but you cant see them anyway. You can also check for bent pins in the CF slot. Sometimes if you shut down the camera in mid write to the card, itll mess up the cards FAT (file directory)
SOURCE: The camera will turn on/off But No image on the LCD
For this I would like to know if any water got into the camera.
If it did, then it more than likely has been shorted out, since you said you turned it on.
Good for parts if that is the case.
Any kind water in any camera spells doom.
If you ever have a digital camera which has any water exposure, then immediately remove the battery and if possible open the camera case by removing at least the back's screws, making a note where each goes. Let the camera dry out for a few days minimum.
Even after this, most digital cameras will not survive the water damage. The circuits are so small and delicate that any water will cause damage. Corrosion will do the most damage as a result of water causing chemical reactions with the solder and other elements. Any small damage to these tiny, delicate circuits will spell doom.
SOURCE: Black with purple lines instead of image in viewing screen
This sounds like it might be a defective CCD imager, and is a known defect for your particular model camera.. If so, Canon should fix this for you for free if you live in the US, Canada, and a select few other countries. If you live outside the US, contact Canon support for your country to see if they'll still honor the advisory (some still will, especially if you stress you knowledge that this is a known defect of the camera). They may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please see this link for more info.
Affected cameras with this problem include:
A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S230, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
