Question about Canon imageRUNNER iR C2880 Color Copier
C2880 tray 1 lifter
C2880 tray 1 not lifting.
Posted by darrylp on
Anonymous
  • 168 Answers
Pull out tray see if there is paper stuck in side were the tray slides
Posted on Oct 23, 2009
Canon E000040-0002
Cassette 1 Lifter error
Unable to detect the lift-up completion position within 4.5 sec after lift-up was started
Remedy
Error in Lift Motor or Lifter Sensor 1. While Cassette 1 is removed, turn ON the power and then insert Cassette 1. When there is operation sound of the motor 1-1. Check the harness/connector between the DC Controller (UN09/J13) and the Cassette 1 Lifter Sensor (PS12) 2-1. Check if the Cassette 1 Lifter Sensor (PS12) is installed. 3-1. Extend the Sensor Flag of the Cassette 1 Lifter Sensor (PS12) by approx. 1.5 mm with Plastic Film, etc. 4-1. Check the condition of the gear at the host machine side (to see if there is missing or swing with the gear) 5-1. Replace the Cassette 1 Lifter Sensor (PS12) 6-1. Replace the DC Controller PCB (UN09) When there is no operation sound of the motor 1-2. Check the harness/connector between the DC Controller (UN09/J13) and the Cassette 1 Lifter Motor (M14) 2-2. Check conduction of the fuse (FU2) of the DC Controller (UN09) 3-2. Check the condition of the gear at the host machine side (to see if there is something missing or swing with the gear) 4-2. Check the Cassette 1 Lifter Motor (M14) 5-2. Replace the DC Controller (UN09)
Feb 02, 2017 | Canon Office Equipment & Supplies
ERROR 0X00000709 PRINTER HP CM6040F MFP
hi,
Error related tray lifting....just check which tray is not lifting and find "is there any kind of abstraction to lift the tray".
Then just refix the tray lifter assy. connector otherwise replace lifter assy.
hope it will help.
Feb 04, 2014 | HP LaserJet Office Equipment & Supplies
HP LJ 4200 does not lift the paper deck, but goes to ready state
If the paper does not lift, remove tray 2 and look inside to your right and you will see the paper lifter. Make sure the spring has not fallen off the lifter. You may need to replace the lifter. Also try lifting the paper deck by hand to make sure there is no obstructions in the tray itself.
Jul 30, 2013 | HP LaserJet 4200 Printer
Tray lifting error hp printer hp laserjet m5035mfp
The tray lifting error is displayed as 60.02 Tray 2 lifting error. To fix this error, check the surface sensor of the paper tray2 in the Manual Sensor Test 2 menu under the Troubleshooting menu.
Connect back the cassette lifter motor and the DC controller PCA's connectors and now, replace the filter driver unit in your printer.
123 hp com Quick HP Printers Setup Easy Installation Guidelines
Dec 16, 2011 | HP LaserJet M4345 MultiFunction Printer
I have a canon copier with colater the colater when you start the machine goes down and just clicks and never comes back up again. The screen gives me error code E000540-0001
E540
Main Cause: The tray home position sensor (PI8) is faulty. The tray lifter motor clock
sensor 1/2 (PI9/PI19) is faulty. The tray upper limit detecting switch (MS5)
is faulty. The tray lifter motor (M5) is faulty. The finisher controller PCB is
faulty.
0001 The ascent does not end in 15 secs when the tray lift motor is
driven; or, the tray home position cannot be detected when the tray
lift motor has been driven for 15 secs.
Feb 10, 2011 | Canon imageRUNNER 6020 Copier
When I try to print, the printer sounds like it wants to print but the paper does not get fed into the machine it just makes a really weird sound.
hi.... First check the lifter *** lifting the tray, when the caridge block move towards the left it pushes the plastic lock of lifter assembly to lift the tray check them for working if it works then go to next step..
clean the feed roolers & replace the paper seprator of the printor satuated on the end of paper feed tray (brown colour).
Your problem will be resolved 100%.
Aug 31, 2010 | HP DeskJet 612c InkJet Printer
How do I get to the drum cartridges on our Canon IR C2880?
open front door remove clip on cover to righthand top push lever in and right hand lower door will pop open remove 2 screw 1 top left 1 top right release black handle and the whole assyembly draws out press button on top and lift up there is a little black support arm to stop it falling down unlock the drum you want to change and remove or just call the engineer if you have a service contract?
Nov 16, 2009 | Canon imageRUNNER iR C2880 Color Copier
Printer won't print
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Nov 20, 2008 | HP LaserJet 4250n Printer
Hp 4700n
Have you would try a different paper cassette.
Usually that clunking noise is associated with gears not mashing.
Is the lifter lifting the platform or not?
There might be something above the paper tray, maybe even the paper input assembly preventing the paper platform from reaching the top.
Check these and let me know what happens.
Oct 03, 2008 | HP LaserJet 4700N Printer
Canon imageRUNNER iR C2880 Color Copier Logo
85 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
