Televison & Video Logo
Posted on Oct 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost remote control in the process of moving but, i have TV and cable connected and all i have on my screen is the settings for selecting language. i cannot turn channel or go to different outputs. my question is, is there any way that i can select language without using standard remote control that came with my TV?
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
  • Posted on Oct 23, 2009
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2820407
Points
26282
U can buy an exact remote in this website.1-800-Remotes Factory Original.Yes,use the control pannel on of ur tv in the front.U have a menu button use that botton get in the menu to change ur language.
Anonymous
Level 3:
  • Master 11,896 Answers
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734611
Points
36074
If there is no menu settings, then you will have to get a universal or origional replacement remote
2answers
I wanna change the language of my Sony Bravia KDL40V2500 from japanese to english and i can't do it. How can i?
Most language options on electronics are found under "Settings"
Switch on
Menu
Settings
Preference
Language
In process of moving misplaced remote can I set up for sat.cable from select onfront of TV?
No idea if you can select you unspecified TV to Cable. Start pushing buttons, some may leed you to the onscreen menu.
So, maybe you can buy a uiversal remote, at nearest retail store or from some websites. Just check it's user's manual if code for your TV is listed.
How d I activate an external antenae
1. Press TV to select the TV mode.
2. Press POWER to turn on the TV. The STARTING SETUP function
begins and the language setup menu appears on the screen.
Press upArrow (^) or downArrow (v)to select your desired
language, then press ENTER.
3. Press (^) or (v) to select TV or
CABLE, then press ENTER.
4. Press (^) or (v) to select START, and
then press ENTER, which
starts the AUTO SETUP.
Note:
To cancel the setup and return to the regular TV screen, press (^)
or (v) to select CANCEL and press ENTER.
5. When the AUTO SETUP is complete, the regular TV screen
appears.
Notes:
• AUTO SETUP of channels may take 15-30 minutes to complete,
depending on your regional cable service.
• To cancel the AUTO SETUP and return to the regular TV screen,
press EXIT.
from TV manual that uses a CT885
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CEcQFjAD&url=http%3A%2F%2Fwww.hdtvsolutions.com%2Fpdf%2F50hp66_om_e.pdf&ei=_KppUvWPNqjSyAHTr4DIAg&usg=AFQjCNGar3aphbJ5yNHl9QMUJsSI6SjCTQ&bvm=bv.55123115,d.aWc
I lost the remote and the tv screen is stuck on the language options which i cant get out of. i have a new remote but cant twin it with the tv until i get away from the page its stuck on???
Best is to switch off the TV . Disconnect all the cables even from wall outlet. Wait for sometime. Let it reset itself. Connect all the cables. Switch on the power. Use the control on the TV to set the TV.
2answers
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Can't seem to switch to input with the remote or go to any channel to use my DVD player
Hello
Check first if the Remote Control hanset emits infrared rays or not. Infrared rays are invisioblw to us. There is an easy way to check it. if you have a cellphone with camera option, set it to camera mode, and place the remote hanset against its lens about 1 feet away or so, and press each button on the remote control. You can see the infrared indication on the screen of your cellphone.
If it is Ok, just reset the remote control.
You might need to reset the remote: remove batteries and press the number 1 button for at least 60
seconds. Release the 1 button, replace the batteries, and (if necessary) program the remote again.
Check also for
Something might be between the remote and the remote sensor on the component. Make sure there is a
clear path.
• Maybe the remote isn't aimed directly at the component (DVD, TV, VCR) that you're trying to operate.
• Maybe remote is not in TV Mode. Press the TV button so remote will control TV.
• Maybe batteries in remote are weak, dead, or installed incorrectly. Put new batteries in the remote. (Note,
if you remove the batteries, you may have to reprogram the remote to operate other components.)
How to Use the Remote Control to Complete
the Initial Setup
The technical term is "Navigation"- how you move through the
on-screen menus. The method is the same throughout the menu
screens: highlight your choice and select it.
To highlight a menu item, press the arrow buttons on the remote
to highlight one of the items listed on the screen. Use the up or
down arrow button to move up or down. Use the right or left
arrow button to move right or left.
To select the item that you've highlighted, press OK.
Note: Highlighted means that the menu item stands out from other
menu items on the list (appears darker, brighter, or a different color).
Turn on the TV
Press TV on the remote, or press POWER on the TV's front panel.
Note: Pressing the TV button not only turns on the TV, but puts the remote
into TV mode. "TV mode" means that the buttons on the remote control
operate the TV's functions.
Complete the Initial Setup
The menu system in your TV allows the TV's features to work
properly. The first time you turn on your TV, the SETUP screen
appears with Language highlighted. The default language is
English. To choose another language, press the right arrow
button on the remote.
If these doesn't work, the infrared sensor inside your Tv has got damaged and should be replaced. OK.
20helpful
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Lost remote control. can't change language
It is always more difficult to operate the menu features of a tv using the manual buttons on the tv. I recommend you unplug the ac cord of the tv from the wall for a day while you go out and buy a universal remote control. After plugging the tv back in and turning it on initially most television on screen prompts immediately direct you to the set up menu which includes setting the language.
Follow the instructions on the universal remote and program the remote to the tv using the power button on the remote to determine if you have reached the right code. It will then be possible to operate the menu features of the tv via the remote control and thus change the language back to english.
2answers
Unable to get cable channel programmed into set
Access the customer menu, select cable vs. ant then go to auto programming and let it do it's magic.
Bill
Language screen won't go away
It seems you need to buy a new remote ,here is all the inf.you need.http://www.remotes.com/remotes/servlet/rs?uid=A1158853432594&o=c&a=Search&o=c&m=md13p1
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
