Question about Kenmore HE2 Plus Front Load Washer
Leaking water out bottom of front load washer
Posted by sshaffer1116 on
Jeff Rockwell
  • 5,911 Answers
You will need to remove the lower toe panel directly below the door to gain access to the inside cabinet to see where the leak may be coming from. The panel comes off by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: Propping the two front feet of the washer up with something (a 2x4 works well for this) will give you better access to the screws.
The most common source of leakage on this washer is the rubber bellow around the door. It can develop cracks or tears over time and require replacement. A tell-tale sign is the front counterweight (looks like a concrete block on the front of the wash tub) looking wet. The counterweight will remain dry if the tub is sealed properly. From the inside of the washer, pull the rubber folds back on the door bellow and inspect the perimeter for any rips or tears. If the bellow is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
If the bellow is intact, check the rear bellow seal where it connects to the front of the wash tub. If the clamp comes loose the bellow can shift and begin to leak. Tighten if necessary.
Check the drain pump and hoses to ensure they are not leaking. The drain pump is directly in the front under the wash tub.
Check the area directly below the wash tub. If the leak is coming from the wash tub iteself, you may have a bad tub seal. A replacement gasket doesn't cost much at all, but the labor involved is extensive.
Check the air dome on the lower right hand side of the wash tub. There should be a small air hose attached that runs all the way to the pressure switch. This small air hose is how the pressure switch senses the pressure differential in the wash tub and determines when to shut the water off. If the air hose comes loose, water will pour out of the air dome into the cabinet bottom. Reattach if necessary.
Another simple problem is the dispenser tube(s) that come through the door bellow. Sometimes, these small tubes will work their way behind the rubber in the door and leak when the washer attempts to fill or rinse. This is a simple matter of adjusting the tubes to ensure they are seated through the door gasket properly.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
NOTE: You can refer to searspartsdirect.com for some excellent exploded view diagrams of your washer for reference in locating components. If y
Posted on Oct 24, 2009
  • Jeff Rockwell
    Jeff Rockwell Oct 24, 2009
    http://www.fixya.com/support/r385211-rep...
  • Jeff Rockwell
    I apologize about the double submission. My keyboard went a little bezerk on me. If you are uncertain of any component location, please post back with your model number (located around the door opening), so that I may able to assist you further. I hope this helps you.
HL04932940 27" FRONT LOAD WHIRLPOOL HE WASHING MACHINE LEAKING WATER FROM BOTTOM
First check is the standpipe drain. The hose that comes from washer should not be inserted more than 4". More than that can cause a syphoning situation that can cause leaks from beneath. If that seems okay you will have to see where water is coming from by observing the machine in action with back or bottom service panel removed (if it has one.)
Jan 06, 2013 | Whirlpool LHW0050PQ Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
Water draining out of the bottom of washer
CHECK YOUR WATER INLET VALVES FOR LEAKS BY REMOVING THE TOP OF YOUR FRONT LOAD WASHER. IF LEAKING REPLACETHE PART.
Dec 09, 2009 | LG WM-2277HW Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer has a water leak coming from the bottom!
usually this is the front seal around the door they do crack with age. you will have to pull the front of the washer off to change it any appliance parts co. should be able to get you one
May 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
Front load washer poured water from bottom
Check for loose hoses or broken connection underneath washer .Unplug machines first before opening up the bottom
Dec 28, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Whirlpool fron load Duet washer leaks
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
8,753 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
