Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
My dryer won't start. None of the buttons will light up when pushed. It is a Bosch Nexxt 100 series. It is plugged in and adjacent appliances (washer) work.
Posted by ciciwag on
Anonymous
    New Friend:
  • 10 Answers
Remove the top panel and check for any wires that may have popped off from there connections!!
Do not forget to unplug the dryer from the power source for your safety!!
Posted on Jan 15, 2010
Bosch dryer won't run
bad air flow switch,check wire diagram.
My bosch nexxt 100 series washer will not start. The spin, wash and finish indicator lights flash simultaneously when try to start.
Make sure dial is switched to 'off'. Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes. If if doesn't work, do it again.
To get the clothes out if you are having trouble, open door manually. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off. The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Click helped if helped.
I have a Bosch washing manchine nexxt 300 series, when i push the on button it will not come on
Check door switch. If OK then your probably looking at a motor control board problem. Ck connections on it. It is located in the back right corner of the machine.To get to it take the back off and it will be on the bottom left.
Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
3helpful
Where do I find the reset button on my Bosch Nexxt 500 series dryer? The dryer will run, but no heat is coming out.
Have a Nexxt 3300 and believe yours is about the same so yes, several screws to remove from the back. Top also has to come off because two screws to the back are under the top. And for the top to come off the control panel has to be pulled away. Only four screws under four white caps to remove for panel to be loosened. The top is attached with two screws in the back and four nylon clips under the top. The red reset button will be easy to see after removing the back. It is attached to the heating element housing. It is not hard to do, just a pain to get to the reset button. Link to Bosch appliance website with give you a diagram to help. http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=WTMC632SUS%2f02&ESHOPTYPE=A Good luck.
6helpful
Panel lights are on. push on button nothing happens
I have experienced the same thing a number of times. To solve, open the door, then turn the knob, and push the start button on and off, and push the delayed start button (3, 6, 12 hour). Then close the door, and retry. This routine seems to reset the system.
4helpful
2answers
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Top Bosch Washing Machines Experts
Marvin
Marvin
Steve
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
