Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint WF840 W machine still full of water error code F 05.
WF840 machine still full of water error code F 05. I tried resetting the machine to wash again last week and this worked.
Tonight we are back to square one, washing is trapped inside and water has not drained along with the error code F05. Please help.
Posted by li_helps on
  • Anonymous Mar 30, 2014
    full with water. Error F-05. How can we solve it?
Karl Wright
    President:
  • 1,653 Answers
Do the following.
  1. Switch off the machine and disconnect the mains power.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
Posted on Oct 23, 2009
Hotpoint aquarius fault code f 05
  • F05 - Pressure switch jammed on full
  • Thing to do check pump is not blocked and clear it then reset machine by unplugging for 5 mins and plug back in if still gets error F 05 then you need a repair call out. hope this helps.
Jan 08, 2012 | Hotpoint Washing Machines
I have a hotpoint wf840 washing machine (6 years old) and the wash program will not complete the drum turns but will not advance to the end or spin and on the front facia it states f-08 what does tis mean
F08 means you have a heater fault and in this case because the water isnt getting hot the program wont advance. Check out the heater and related wiring. If you dont already know the heater is at the rear of the machine. For more information about error codes go to www.selfix-uk.co.uk
Jan 31, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima wf840, what does this mean F-05
F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Apr 30, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint WF840 error code F-05 how do I check pump for blockage and how do I empty machine of all clothes as door lock will not release?
remove drain hose from pipe at back and drain all the water in to a bucket or bowel this will take 2/3 goes then the door will open.your problem is the filter or pump is blocked check filter first its at botton of machine mbehind a panel it just pulls off
Mar 03, 2010 | Washing Machines
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
H20 ERROR
This error means - Problem is in the inlet valve.
Your inlet valve at behind top of machine is defective or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem then you need to change inlet valve.
Good Luck!!
Thanks
Jul 24, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf840
f05 meas not drained. usually due to a blockage in your filter.
you will need to get the water out by holding the drain hose lower than the machine into a basin. when drained the door can be opened. unscrew the filter and check for coins/socks etc.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Displays F-03
NTC fault its electronic and needs engineer
But try this for most electronical faults first switch off mains wait 20secs and switch back on this resets most gadgets and gizmos if it doesn't work it was a free try.
Nov 07, 2007 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
604 people viewed this question
Top Hotpoint Washing Machines Experts
Richard C Cohen
Richard C Cohen
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
