Question about Protron PLTV-32 Television
I have a Protron, PLTV-3250 and I need a manual so the Directv can program the remote. Can you help me?
Posted by dsjcrafts on
coyotedave
    Sergeant:
  • 280 Answers
That is a Chinese set and most remote codes will not work. Must use OEM remote.
Posted on Oct 23, 2009
Just bought a used Protron PLTV-3250. No owners manual or remote. Could i find them? Do i need them? Thanks a million.....Pam
It is the same as Spectroniq 3250: Manual
http://www.retrevo.com/support/SpectronIQ-PLTV-3250-TVs-manual/id/926dj283/t/2/
Original remote is hard to come by, try EBAY, without orignal remote you may nat be able to access all the on screen setup functions. Watch out for the power supply module to go out on this TV.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Sep 30, 2010 | Protron PLTV3250 32 in. LCD Television
Protron pltv 3250 power cord
It is the same power cord as used for your PC, NEMA5-15P to IEC C13.
This TV has known problem with power supply, so keep an eye on it.
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 18, 2010 | Protron PLTV3250 32 in. LCD Television
No power on my protron pltv-3250. Any advise? larry
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
May 13, 2010 | Protron PLTV-32 Television
My remote control went out for my Protron PLTV 3250. What can I replace it with. It seems nothing works not even one I ordered on ebay!!
Try at remotes.com This is the one that they indicate is compatible with your TV: http://remotes.com/store/protron/pltv3250.html
Dec 21, 2009 | Protron PLTV-32 Television
I have a PLTV-3250. Is the remote still
The original remote is no longer available. The substitute can be ordered from
Please rate this solution. Thanks.
Sep 14, 2009 | Protron PLTV3250 32 in. LCD Television
Tv has no power - Protron PLTV 3250
Look at the othewr posts for Protron PLTV - 3250. You need a power supply.
Aug 16, 2009 | Protron PLTV3250 32 in. LCD Television
DirecTV Setup Code
Satellite providers are pretty good at keeping their codes current on their websites;
http://2getdtv.com/directv/tv_codes.html
Your brand is listed with several to choose from.
If none of these work, there are dozens of 'learning remotes' on the market that allow you to use the original remote to program the new one.
Not all of them are perfect; research them first.
Jul 07, 2008 | Protron PLTV-32 Television
Remote control programming- Directv
if you have gone through all of the programming codes; you will just have to use the remote that came with the TV set. there is no way to program more codes into the remote, due to its list of codes it was made with can not be updated. i hope this helps
Jun 23, 2008 | Protron PLTV-37 37 in. LCD Television
Protron pltv 32 directv remote code
Protron 32", new Directv R66 receiver/remote. Code is 10030. Works
Feb 02, 2008 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
Top Protron Televison & Video Experts
Jayesh Panchal
Jayesh Panchal
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
