Question about Toshiba Satellite P105-S6084 Notebook
NO power Power supply is good, but the computer will no power up. No lights or anything
Posted by jesemail on
Anonymous
  • 43 Answers
Check the battery of your notebook pc .
when you charging it then try to turn it on if it starts and shuts down when you remove charging them there must be problem of the battery,then you have to change your battery from Toshiba service center.
Posted on Oct 23, 2009
I have a compaq cq5110y computer. When I push the power button nothing happens. It doesn't turn on, no fan or lights come on either. The only light that is on is on the back of the computer and it's a...
It might be a connector cable between the mother board and the power supply has worked loose when the machine was moved. That blinking light appears to be on the power supply.
While there might be other causes, I suspect the power supply needs to be replaced.
You could take up considerable time and try to reseat everything and check all the connections and even put new thermal paste between the CPU and heatsink, but in the end, I suspect putting in a new (or used of the same type) power supply will be the fix. If the power supply has failed before damaging anything, that at least would be good news.
Feb 17, 2015 | Compaq Computers & Internet
Won't start up
Either power or logic board problem. If it chimes but does not boot and the screen lights up then it is a good sign. Will it do anything?
If does nothing try a different power supply first.
Try removing battery and disconnecting power supply, then try to start it without battery and just power supply.
then try charging the battery overnight. If the lights on the battery show any charge after a few hours with it plugged in and the computer turned off, try letting it charge overnight and then try starting it without power supply connected. If none of these thigs help, I would have to look at it.
Apr 05, 2014 | Apple iBook G4 (Z0AZW13397068) PC Notebook
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
Power supply seems to work fine until it has a load on it. Puts out 13.8 volts, but will only handle about 2 amp load before the overload protection kicks in. My 2 amp load test is an 1157 light bulb and...
Note: I'm answering your post with the assumption that you plan on using this power supply with a computer. If this is not your intention, please disregard my solution attempt.
You likely already know this, but if you are powering a computer you're going to need a power supply with more wattage. I would recommend nothing less than a 350 watt power supply.
Follow this link to calculate how much power you need to run your computer: http://www.extreme.outervision.com/psucalculatorlite.jsp
If you're not ready to give up on your 270 watt power supply, then remove all PCI/PCI-E devices, USB ports, extra fans, non-boot hard drives, extra DVD/CD drives etc. one at a time until the computer powers up. Anything you can do to reduce the load on the power supply will help.
Good luck and thanks for using FixYa.
Mar 08, 2011 | Pyramid PS14KX 270-Watt Power Supply
Won't turn on. switch is good
Check the obvious. Is it plugged into an outlet that is "hot"?. Is the switch on the back of the computer in the power supply ON? Does it do anything (i.e. fans turn on, click, buzz, lights???).
Could be the power supply is inoperative. This is a fairly common problem on emachines. They use a minimum power supply and if you add ANYTHING to the computer, (like a better graphics card), the power supply cannot handle it.
To get into your problem you will need a circuit tester/volt meter. If you DON'T have experience with doing diagnosis, it's better left to some who does know. You could end up with a very expensive doorstop....
Good Luck and reply with what you find out from ym suggestions.
Jan 30, 2011 | E-Machines eMachines T3830 PC Desktop
The computer does not turn on
First--does it do anything at all? No lights, no fan, no hard drive spinning up?
No?
Then your power supply most likely is bad and must be replaced.
Feb 02, 2010 | Dell Dimension 9100 PC Desktop
Powers up but the picture is so faint that you can not make anything out. what might be the problem. power supply is good.
bigred7648, The power supply inside unit needs work. You have typical failure of either the "switch-mode-power-supply" or the "inverter" circuit that supplys 500-1000vac to light-up the fluorescent lamps (CCFL's) on rear of your LCD panel. 12fixlouie
Dec 05, 2009 | GE KLC-15HS (Gray, Silver) 15 inch LCD...
My gateway desktop PRB 510S, if I turn it off and unplug it or electricity goes off, the computer wont start back again. Wont do anything. No lights no fan, nothing. Then 5 to 10 minutes after I turn it on...
Try connecting a different power supply to it. If the same situation repeats, then it's an internal (motherboard) problem. If the problems go away, then the power supply needs to be replaced.
6 years... I'm surprised the PSU even lasted that long! The power supply is the cheapest part of the PC and usually one of the first parts to fail. Don't worry, a replacement power supply is not too expensive. Good luck!
Dec 02, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Green led light flashing on 700p proview flat panel and no picture
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Toshiba Satellite P105-S6084 Notebook Logo
94 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
