First, 3 beeps means that the unit was in the freeze cycle too long and the 60 minutes back up timer kicked in and took over.
Now, for the water flow/ head pressure water cooled control.
You set the water flow for what ever it takes to achieve a head (High Side) pressure of 270 psi. the gallons per minute are of no matter. It's the pressure that you want to achieve and maintain.
If you fix the head pressure problem, the beeps should go away.
If you don't have a gage set, then measure the temp of the exiting water from the condenser. It should be in the 104 to 115 degree range. Any lower or higher, and the unit will not run like it was designed to do.
Hope this knocks it out for you.
