Question about Samsonite Tripod
TSA locked our TSA002 lock on our samsonite bag when they inspected it. We do not have a key. TSA said we needed to go back to the airport, but is there a way to get a key?
Posted by cscudi on
Obertelli
    Brigadier General:
  • 3,006 Answers
No. That's part of the whole purpose of TSA passkeys; they're held securely and only at ports. If it were easy for anyone else to get hold of them the locks which are TSA approved would become pointless.
You only have three options if you do not want to return to the airport:-
1. Get a locksmith;
2. Cut the lock off/drill it out;
3. If your lock is usually key operated (not a combination) then there will be a number next to the lock barrel (not the TSA number, that just tells the TSA which of their passkeys to use). A Samsonite dealer can order the correct key for you using the number and some even keep them in stock.
Posted on Oct 23, 2009
Samsonite luggage
That keyhole is so that TSA can open that lock and take it off. They only time they would do that is if your are flying on a plane and the bag is in checked luggage and it needs to be searched.
May 01, 2014 | Samsonite Large Dial Travel Sentry Combo...
How to unlock samsonite combination lock?
1. Call Samsonite Customer Service at 1-800-262-8282. Representatives are available Monday through Friday from 10:30 a.m. to 5:30 p.m EST.
2. Press "1" and then "6" on your telephone keypad to speak with a representative to order a replacement key or padlock.
3. Pay the required fee. Samsonite will then send out the replacement key.
Aug 17, 2012 | Samsonite Tsa Acceped Padlocks Allow You...
TSA locked my luggage after searching and I dont know the combination
Hello; The only the thing I can say is take back to the airport make TSA open it or a profesional lock smith that will cost you. If the airport is not to far away Id carry it back to TSA
Aug 30, 2011 | Samsonite Tripod
I have a TSA002 lock which came with the luggage bag and having set the code accidentally, I've not been able to decode it. How can the problem be solved? I know there's a keyhole and a TSA 002 key will...
http://www.youtube.com/watch?v=OfchUwkEckI&feature=related
This link actually shows a man picking a TSA002 lock with a pair of standard tweazers. You can give that a try??
Sep 05, 2010 | Samsonite Tripod
URGENT!! Please help!! We are locked out of our Victorinox mobilized NTX hard side extra large wheeled travel bag. Need to figure out how to re-set the lock on it.
Simple, just have airport security open it up for you. Which they will do with normal identification. The lock as a universal security by pass.
{ ... Custom-made Travel Sentry® Approved Lock is integrated into the aluminum frame and allows TSA screeners to open the lock without destroying it, and relock it after inspection ... }
http://www.surrayluggage.com/vnox303503.html
Aug 14, 2010 | Garden
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
I HAVE THE TSA COMBINATION LOCK ON A SAMSONITE GRAVITON G LUX
I can't answer the problem - but am interested as we had an identical failure on holiday in South Africa. We had to force the case open as the lock and the mechanism seemed to have come adrift in that when moving the lever with the correct combination - the case neither opened or closed. I'm sending it back to Samsonite under warranty to hopefully get it repaired/replaced. I rang the UK number listed on the Samsonite website. Bit disappointed as Samsonite should be more reliable - particularly given the price of the case, at £295, isn't exactly cheap.
Apr 11, 2009 | Samsonite Tripod
Forgot my 3 digit number lock on my samsonite bag
lost 3 digit no on samsonite TSA002 lock
Sep 17, 2008 | Samsonite Tripod
Photography Logo
8,961 people viewed this question
Top Samsonite Photography Experts
Richard Schabler
Harrie
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
