My 2001 Honda accord has a radio that wont shut off even when the engine is off and the key is removed. The volume will not adjust, stations will not change and the cd player will not accept a disk. I pulled the fuse so that it wont run down my battery. Is this a deeper problem? What do you suggest might be the reason it does this?
I agree with SteveAlaska, it it also possible the radio has an internal short causing this condition. Either way if you are comfortable with basic electrical work I would recommend removing the radio ASAP so it does not drain your battery. Then checking the wiring for and issues. If you are unfamiliar with wiring/electrical I would take the car to a shop you trust to diagnose the issue, or the shop who installed the radio (if it is not the original)
If this is an aftermarket radio, they hooked it up wrong when they installed it. Either way, this is a wiring issue. Remove the radio and make sure the wiring harness is corrected before installing again. Good luck!
SOURCE: 1998 - 2002 Honda Cassette 6 disk CD changer Radio
the cd changer is malfunctioning, the factory cd changers usually don't last that long because of the heavy use and many mechanical puts
SOURCE: 92 honda accord camber adjustment
There is no no camber or caster adjustment on that model. If the car has been in an accident, chances are something is bent. My experience has been that the shock body and/or the steering knuckle is bent. Parts replacement is the only true fix. If the vehicle has had the ride height altered, ie. lowering springs, then there are adjustable upper control arms and ball joints available. These do generally only address the camber angle, not caster, which can also greatly affect handling. hope this helps.
SOURCE: 1999 Honda Accord radio/CD needs to be reset; what is the code?
The reset code is posted on the left or right hand side of the glove compartment. Open and enter the code on the audio controls (numbers).
SOURCE: Connect iPod to OEM radio for 2001 Honda Accord
Just get the FM transmitter for ipod/MP3 player ( $10-15 in Walmart for example). It will be like an another station in FM at your radio. You can buy even a kit including car charger and fm transmitter in one piece.
Please kindly let me know if you need more info
Good Luck
