Gilbert, este fusor es un consumible y no existe despiece
cambiar fusor pq existe una diferencia de velocidad en los extremos del papel al atravesar el fusor
Check pressure on fuser/check your drum fingers/could be media
This sounds like a wrinkle. The paper is acually shrinking. Sometimes the paper will go in crooked and still feed, but the copy comes out wrinkeld.
Not seeing the machine, a fresh xerographic type paper would be needed to test the machine.
Paper that is used used for Ink Jet printers usually will wrinkle. Make sure xerographic paper is used.
If all these conditions are good, then try replacing the presure roll or both presure roll and heat roll. If the two are not available, replace the fuser assembley.
Hope this works.
Check the pressure of the fuser adjustment
