Question about Candy Freezers
Freezer had been working well for a month or more, then following it being moved possibly as a workman was checking my appliances for leaks, the top of the inside grew thick ice. I defrosted it but within a week it has become very thick again. suggestions?
Posted by jmcbain52 on
Terence Fourie
  • 909 Answers
Normally that amount of ice denotes a leak in the system, or possibly the thermostat not switching off. If the door does not seal correctly, you will also generate a lot of ice. Something tells me we are looking at a leak.
Posted on Oct 23, 2009
Have a upright freezer and the meat on the top shelf is thawed out but the rest of the food on the lower shelves are frozen. Is it a vent problem
Either the door seal is bad or the freezer has a refrigerant leak or a bad compressor. Best to have an appliance tech check it. It won't take him long to locate the issue.
Nov 04, 2017 | Freezers
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 | Freezers
Ice maker leaking into ice tray making icebergs
The icemaker could need seal replacement. Check with an appliance parts supplier.
Apr 14, 2014 | Maytag M1TXEGMYB 20.6 Cu. Ft. Top-Freezer...
My Frigidaire Heavy Duty Upright Freezer is not freezing. The compressor is running. Only the first section of the coil in the top rack is getiing cold. Manufacture date is 2002 and it's been used for...
Yes, it does sound like you have a slight leak and a recharge is needed...
But...
Be very careful as to who you get to do that as many are not experienced enough to work on fridge units...they are very touchy and need to be serviced by someone familiar with the small refrigeration units and also someone that is licensed to use refrigerants...
heatman101
Feb 02, 2011 | Frigidaire 20.6 cu. ft. / 583 liter...
FREEZER IS NOT FREEZING IT IS 18 MONTHS OLD. WE DEFROSTED IT AND IT FROZE AN ICE CUBE TRAY SO WE MOVED IT DOWN STAIRS PLUGGED IT N AND IT NOT FREEZING AGAIN????
It is possible to cause an air lock when moving an appliance by tilting it and then not allowing the refrigerent to settle before switching on. Try unplugging it and laying it on its side for a couple of minutes, then put it upright and leave it for 6 hours to settle, then plug it in again.
Nov 28, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer bubbling coming from top of freezer inside
hi thanks for the question .when the fridge shuts off the freon is boiling in the freezer that's what makes it cold is the boiling so what your hearing is normal you don't have a leak thanks the appliance doc
Sep 28, 2008 | Electrolux Freezers
Chest Freezer doesn't get cold
Was this unit placed on its side or back? This can cause oil to get where it shouldn't and block freon flow. If the unit has not been moved this is not an issue. Could be the compressor but sounds more like low freon level. Most leaks happen when units are turned off for long periods. I don't ever believe in charging a deep freeze unless you can positively say you have found and fixed the leak. You can never really trust it again and the food inside is usually worth more than the freezer.
Jun 24, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Freezer quite working after an electrical surge in area...
tell her to change the rely on the compressor if there is an appliance parts store tell her to get a three in one reley and follow the instructions that come with it
May 25, 2008 | Freezers
My freezer
Be sure your cords in the back are plugged in, and you shut the door completely, if you move the freezer to check if it's plugged in, don't pass out when you see all the lint!
Nov 29, 2007 | Freezers
FREEZER NOT WORKING
that is very possible if the fan and compressor are running. the best thing you can do is call maytag. its only 4 months old and is there problem to fix. Good Luck
Aug 03, 2007 | Maytag Freezer MQU2057
Freezers Logo
101 people viewed this question
Top Candy Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Candy Freezer Expert? Answer questions, earn points and help others
