How can i replace the video card / chip on a dell precision m2300?
Posted by raulgking on
  • raulgking Oct 24, 2009
    Ok, maybe i wasn't specific enough.
    The dell precision m2300 is a notebook.
Burraq Consulting
  • 139 Answers
U cant replace builtin card ...if there is a PCI or PCI-E solt in ur motherboard then u can insert a new card there.
Posted on Oct 23, 2009
  • Burraq Consulting Oct 24, 2009
    well then take it to dell service centre they will replace the card.. cuz its quite complicated you cant do it by urself
A padlock is flashing
There should be a hole next to the button on the CD drive that you can use a paper clip to open the drawer.Also go into setup and make sure CD drive is first boot device.
Feb 14, 2014 | Dell Precision Computers & Internet
NO DISPLAY PROJECTED. VERIFIED MONITOR. DELL SHOWS LIGHTS 1 2 3 IN GREEN.
I don't think that machine has an onboard video card, so try removing the existing video card from it's slot. Clean the contacts on the video card GENTLY with a pink pencil eraser. The eraser has just enough abrasive in it to clean the oxidation off the contacts. Replace the video card and see if it works. If not, test with another video card.
Hope this helps!
Joe
Jun 04, 2011 | Dell Precision Workstation 690 - 750W...
What type of vga card do i need for a dell precision 470
To take Full advantage --You have High-Speed PCI X (express) slot-(if its not already being used for something else)--and dont forget that you will need to disable the integrated one first.
Jan 02, 2011 | Dell Precision 470 PC Desktop
Dell M2300 issues: After several times of a freezed screen & rebooted the computer while either on the internet or working with "Autocad Inventor", it's finally gave up on me, on the last...
Isolate where the problem is: it could be the LCD display or the graphics circuit on the main board. Connect the VGA output of the laptop to an external monitor - one that you know is good. From the function keys, activate the VGA output of the laptop - it's suppose to switch between the LCD display or to the external monitor. Switch it to the external monitor. If the external monitor works, then you have a problem with the LCD display of the laptop.
Dec 22, 2010 | Dell Precision M2300 Computer Workstation ...
My computer screen flickered several times and then turned black. i turned it off and tried to turn it on again. it will turn on and the sound works but the screen is still black
you have a GPU that is cold jointed (bad soldering from cycling heat and cold stress) you must reflow the graphic card
first try connecting an external monitor, if it works it's the LCD panel need's to be replaced
if you have the same problem with the external monitor you have a GPU that needs REFLOWING find a company that can REFLOW the graphic card (re heat the board to re solder the GPU)
Have fun!
Nov 07, 2010 | Dell Precision M2300 Computer Workstation ...
My dell precision 470 keeps burning video cards
Have you replaced the power supply at some point? You may have the wrong power supply...Your processor may not be able to handle the Graphic Card that you're trying to use...Graphics cards are very demanding on a computer and you may have pushed your computer beyond its limits with regard to how much graphics it can handle...
Oct 29, 2010 | Dell Precision 470 PC Desktop
Hi my dell precision m90 has problem. While I'm doing some work it instantly shot down without any warming. From other answers from your site can be an overheating problem but a run the check for all the...
The M90 has 2 fans (1 processor and 1 video card) http://support.dell.com/support/edocs/systems/wsM90/en/sm/fans.htm#wp1000550
while the fans can be passing diags, the system could still be having a cooling issue. Some things you can do are:
  1. Use some canned compressed air to blow out the fan intakes and exhaust ports. The hear exchanges can become clogged with dust and debris causing the cpu or video card to overheat.
  2. The M90 video card is replaceable. If the issue is re-occurring on a regular basis, there is a decent probability the issue is the card. Try booting to the F8 Menu and run system in the VGA mode to reduce the load on the video card. If the system runs without issue in this mode, then the video card is suspect.
  3. From OFF, Hold the Fn key and press the power button to initiate diags and see if you get a diagnostic failure.
  4. Update the bios and video drivers, see if issue resolves.
If issue still occurs after all of the above, then replacement of the video card may be required
Dec 05, 2009 | Dell Precision M90 Notebook
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
I am having performance issues with network connectivity
download a program called spybot s&d (google it)... install it.. update it and scan your computer... remove all the spyware it finds... next upgrade to IE7
Robert
Jan 22, 2009 | Dell Precision M2300 Computer Workstation ...
Webcam plasmon c-005
Try using compatibility wizard
May 31, 2008 | Veo Mobile Connect Webcam
Computers & Internet Logo
127 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
