Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
