Question about RCA Televison & Video
RCA Universal Remote Code For A Trinitron Xbr Tv
What Is The Code For A Trinitron Xbr Tv Using A RCA Universal Remote?
Posted by jseifer on
david mcclellan
  • 530 Answers
There are several RCA universal remote models. With out your specific model # I can only give you the most common code. 002.
You can also try the steps below to use the internal code search mode if your remote has this feature.
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Posted on Oct 23, 2009
What is the code for my Sony Trinitron Wega 32" TV using a RCA RCR311 B universal remote?
Try this
http://www.retrevo.com/support/RCA-RCR311-Universal-Remotes-manual/id/402ci569/t/2/
Aug 29, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCU410MS code for Sony Trinitron KV-27EXR15
get a SONY universal remote number RM-U302 it needs no codes just press the SONY item say in your case TV and the remote will self calibrate to your type
Jul 11, 2013 | Televison & Video
TV code list for Sole Universal remote control
082,081,095,027,002 are the codes to check with RCA brand TVs. If you wish to get more details, check the links given below. Setup code list and setup proceedings to many popular brand remote controls are given. Pull up older posts there. More than Nine Lacks viewers cannot be wrong.
http://electrohelponline.blogspot.com/
May 06, 2013 | RCA Universal Remote Control
I need the code for a Sony Trinitron tv and I am programming it with a RCA RCU403 universal remote... and can you help in programming also please?
Hello
There is only one setup code for Sony TV with this remote control. It is:
0001
Try it. Best of luck.
OK.
Aug 15, 2011 | RCA Universal Remote Control
Lost code book for RCA universal remote control
Hi. here is the code you have requested. 002
have a great day
Mar 24, 2009 | RCA Universal Remote Control
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Televison & Video Logo
606 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
