Can't change the battery in a Sports Instruments Pro 7 HRM. Has a retaining clip I can't remove.
Thanks.
These clips can be troublesome but they almost always have a release.
It may require magnification to find the release which you will either push, pull or both to release. Just go slow and you will succeed.
Good luck and post again if you still can't find it under magnification.
Use a paperclip. bend it straight, stick it between the hole in the clip and pry it out and around the plastic part. I switched both my batteries but now it does not synch with my strap.
